????????Need Help????????
Old Sep 27, 2004 | 04:54 PM
civic91's Avatar
Default ????????Need Help left two washer behind????????
I bought a 2000 integra front seat to replace my 1995 front seat. I searched before purchasing the seat and a lot of H-T member said that its a bolt on but unfortunately its not. I need to swap the rails/slider, here's my question how can I remove the 2 adjustment ***** on the driver side? Please look at the boxed area, this is the reason why its not bolt on. thanks for any suggestions.
http://www.ofoto.com/PhotoView...71406
Modified by civic91 at 8:22 AM 9/28/2004
Modified by civic91 at 12:13 PM 9/30/2004
Old Sep 27, 2004 | 05:29 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: ????????Need Help???????? (civic91)
I recommend this site for the exploded diagrams.
http://www.acuraparts247.com
Do those ***** need to be removed to install the seat? Would it be possible just to swap the cushions and upholstery?
Old Sep 27, 2004 | 05:35 PM
civic91's Avatar
Default Re: ????????Need Help???????? (Dogginator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">I recommend this site for the exploded diagrams.
Do those ***** need to be removed to install the seat? Would it be possible just to swap the cushions and upholstery?</TD></TR></TABLE>
I'm not sure which one is easir to swap the cushions and upholstery or the rails and slider. I started to dismantle the new seat but I don't have enough tools to remove all the bolts and two of the bolts are pretty tight that I got scared I might brake it. Thanks for your suggestion.
Old Sep 27, 2004 | 05:47 PM
LSvtec03's Avatar
Default Re: ????????Need Help it's not bolt on???????? (civic91)
i think you're mistaken. all 94-01 integra front seats mount in the exact same way/same places. you should try again and slide the rails around to get them to line up with the bolt holes.
Old Sep 27, 2004 | 05:50 PM
civic91's Avatar
Default Re: ????????Need Help it's not bolt on???????? (LSvtec03)
That's not my problem if you look at the picture, the rail (front) is not bend, may be the old owner of this seat swap the rail or something.
Old Sep 27, 2004 | 06:39 PM
civic91's Avatar
anybody........
Old Sep 27, 2004 | 06:49 PM
.water's Avatar
helm book shows nothing about bolts..so i guess just pull them off..there is clip too..like U shape clip..sorry i dont have scaner..
Old Sep 27, 2004 | 06:56 PM
civic91's Avatar
Default Re: ????????Need Help it's not bolt on???????? (Milano-Red GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Milano-Red GSR &raquo;</TD></TR><TR><TD CLASS="quote">helm book shows nothing about bolts..so i guess just pull them off..there is clip too..like U shape clip..sorry i dont have scaner..</TD></TR></TABLE>
can you take picture of the page that show the U shape clip? What's the instruction in the helm book just pull them off? thanks in advance...
Old Sep 27, 2004 | 07:07 PM
UnKnownUser's Avatar
Dam,what page is that on helms i could get the picture for him i have helms in pdf so....
Old Sep 28, 2004 | 05:44 AM
civic91's Avatar
am bump
Old Sep 29, 2004 | 05:25 AM
civic91's Avatar
anybody????
Old Sep 29, 2004 | 06:23 AM
Rory Breaker's Avatar
It should bolt right on...if it doesnt, whoever you bought it from isnt telling the whole story.
Old Sep 29, 2004 | 06:51 AM
wanna b R's Avatar
Default Re: ????????Need Help it's not bolt on???????? (newgsrdriver)
i have a 94 teg and i put in 2000 integra GS R seats in with no problem just bolt right in....i think the guy who sold you the seats change the rails or something..
Old Sep 29, 2004 | 09:39 AM
civic91's Avatar
Default Re: ????????Need Help it's not bolt on???????? (wanna b R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wanna b R &raquo;</TD></TR><TR><TD CLASS="quote">i have a 94 teg and i put in 2000 integra GS R seats in with no problem just bolt right in....i think the guy who sold you the seats change the rails or something..</TD></TR></TABLE>
that's what i'm thinking that's why i want to swap rails, but i want somebody to tell me how to remove the adjustment **** so I can get to bolt that hold the rails/slider. can i just pull out the ****? all i'm asking is how to take the **** out? thanks again.
Old Sep 29, 2004 | 09:53 AM
Dogginator's Avatar
Daisy... Daisy...
There should be a retaining clip inside of the ****. Remove that and the **** should pull off. The clip is item 23 in this picture:
Old Sep 29, 2004 | 10:04 AM
bluecivic107's Avatar
Looks as though the tabs on the rails have been bent up (circled in the pic)... Try bending the tabs approximately 15 degrees down...I'll bet they line-up to the mounting holes. If NOT just swap rails....
GOOD LUCK!!!
Modified by bluecivic107 at 3:05 PM 9/29/2004
Old Sep 30, 2004 | 05:50 AM
civic91's Avatar
Default Re: ????????Need Help it's not bolt on???????? (Dogginator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">There should be a retaining clip inside of the ****. Remove that and the **** should pull off. The clip is item 23 in this picture:
Thank you very much. That's the info I was looking for.
Old Sep 30, 2004 | 05:55 AM
civic91's Avatar
Default Re: ????????Need Help it's not bolt on???????? (bluecivic107)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluecivic107 &raquo;</TD></TR><TR><TD CLASS="quote">Looks as though the tabs on the rails have been bent up (circled in the pic)... Try bending the tabs approximately 15 degrees down...I'll bet they line-up to the mounting holes. If NOT just swap rails....
GOOD LUCK!!!
Modified by bluecivic107 at 3:05 PM 9/29/2004</TD></TR></TABLE>
I did swap the rails yesterday afternoon after work and the seat is in my car now but after bolting the seat back to the car I found this two washer (1 plastic and one real thin metal) here's the link to the photo, sorry until now I can't figure out how to insert picture.
http://www.ofoto.com/PhotoView...42406
Old Sep 30, 2004 | 09:49 AM
civic91's Avatar
[/QUOTE]
[/QUOTE]
can someone identify this two washer for please.......................
cbp_crx
Dec 26, 2005 08:01 PM
1whitedc2
Jan 24, 2005 03:35 PM
EM2MoNsTeR
Aug 1, 2003 12:45 PM
Civic44
19
Apr 21, 2003 09:06 AM
