shock help
Old Sep 29, 2004 | 01:45 PM
antzemail's Avatar
Default shock help
my friends sellin tein full threaded coilovers off his EF just wanted to know if theyll fit my DC2
Modified by antzemail at 5:19 AM 9/30/2004
Old Sep 29, 2004 | 01:51 PM
purplegsr's Avatar
Default Re: shock help (antzemail)
I assume you mean his CRX HF, they will fit if you get front drop forks from a DA/EF chassis car. However, the shock should be a little shorter and the spring rates will be made for a much lighter car - so you could end up with a very low car with a bouncy ride.
Old Sep 29, 2004 | 06:41 PM
Negative3Five's Avatar
Default Re: shock help (purplegsr (Exospeed))
I think the kid has a 90 hatch I was interested in buying them for my EK but didn't kno if they would fit... but I think he's also sellin his shell so all he would need is the a arm off them for his dc?
Old Sep 29, 2004 | 06:47 PM
purplegsr's Avatar
Default Re: shock help (Negative3Five)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Negative3Five &raquo;</TD></TR><TR><TD CLASS="quote">I think the kid has a 90 hatch I was interested in buying them for my EK but didn't kno if they would fit... but I think he's also sellin his shell so all he would need is the a arm off them for his dc?</TD></TR></TABLE>
The fronts would fit on an EK with a DA/EF front drop fork. But the rears will not bolt up, I think the rear shock has a narrower bracket then used on the DA/EF/DC.
Old Sep 30, 2004 | 09:46 AM
antzemail's Avatar
so its a no go on the coilovers?
Old Sep 30, 2004 | 09:52 AM
purplegsr's Avatar
Default Re: (antzemail)
I wouldn't use them, it would cost you an extra $20-50 for the front drop forks (used) and you would still be left with a very low car and an unpredictable ride because the shocks/spring rates weren't made to handle the weight of your car.
Old Sep 30, 2004 | 10:04 AM
antzemail's Avatar
Default Re: (purplegsr (Exospeed))
aight thanx alot for all your help
cliniCrx
Suspension & Brakes
May 24, 2010 04:58 PM
autowrench07
Nov 17, 2009 06:22 PM
CRXdan
13
Nov 25, 2008 02:48 PM
RMXmitch
Jan 2, 2007 07:34 PM
ShadyBAB
13
Jun 11, 2005 03:29 PM
