i want 200whp b20vtec
Old Sep 27, 2004 | 03:12 PM
MI4eg's Avatar
Default i want 200whp b20vtec
im new to all motor and i really want to run a b20vtec but i want to make 200whp also...
how much power does a stock b20 with a b16 head make? will a gsr head be better or will i be able to hit my goal with a b16 head?
Old Sep 27, 2004 | 03:40 PM
smart monkey's Avatar
Default Re: i want 200whp b20vtec (MI4eg)
if you just slap a head stock on a stock block with ITR cams then you would probably churn about 160-170 whp give or take. ecu choice and tuning is important. I like the gsr head for torque with stock intake man and IAB's working.
Old Sep 27, 2004 | 04:01 PM
slammed00si's Avatar
from what i have read it isnt all that hard. you just need higher compression and tuning.
Old Sep 27, 2004 | 04:44 PM
EKhatch's Avatar
Easy.
Bone stock B20Z bottom end with DIY valve reliefs.
Slightly worked GSR head with JUN 3's
GSR intake with no butterflies and any decent flowing header.
210hwp with Hondata (tuned).
Old Sep 27, 2004 | 04:47 PM
92RED Hatch's Avatar
Default Re: i want 200whp b20vtec (EKhatch)
yeah its really not hard to hit 200 hp with a b20 vtec. But if you do it take your time and spend the money on making the bottom end stronger than stock. The B20 motor was not meant to be a constant high revving motor..good luck..
Old Sep 28, 2004 | 12:14 AM
Odiedogcx's Avatar
AIRBORNE
Default Re: i want 200whp b20vtec (92RED Hatch)
go to http://www.importreview.com and go to the dynos .. then click the 2.0 liter section .. has 20+ b20vtecs with dynos and lists their setups. It's not hard at all to get 200whp with the b20vtec.
Old Sep 28, 2004 | 07:08 AM
Power Rev Racing's Avatar
Default Re: i want 200whp b20vtec (Odiedogcx)
Get some 11:1 or 11.5:1 pistons.
GGcivicEG
40
Nov 7, 2016 01:33 AM
ChInKsTaH
Jun 10, 2008 01:42 PM
boostedek9
Mar 4, 2006 04:49 AM
erbinone
Aug 6, 2003 03:42 AM
JDMs1eeper
Dec 13, 2002 08:29 PM
