one way valves?
Old Sep 27, 2004 | 01:06 PM
grover's Avatar
Default one way valves?
on my dohc zc which I turbo"d I'v been getting the engine light to come up when I boost it,,and its the map sencer, I have 1 valve in it already at the front of the throttle body where the vacume line is to the map sencer,,,,, I'm wondering if that is enough or do I need to put more in and where?
Old Sep 27, 2004 | 01:35 PM
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
Default Re: one way valves? (grover)
» Search Results
Your search for check valves returned 49 results.
search.
Old Sep 27, 2004 | 01:47 PM
Mugen Dom's Avatar
Default Re: one way valves? (Built B16A)
probably should have searched or gone to the forced induction forum oh well better luck next time
Old Sep 27, 2004 | 01:48 PM
Revolver's Avatar
Default Re: one way valves? (JdMB16Ahatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JdMB16Ahatch &raquo;</TD></TR><TR><TD CLASS="quote">probably should have searched or gone to the forced induction forum oh well better luck next time</TD></TR></TABLE>
Old Sep 27, 2004 | 01:50 PM
Built B16A's Avatar
Default Re: one way valves? (Revolver)
and by the way, i did search "check valves" in the FI forum. 49 results. for both OBD0 and 1.
Old Sep 27, 2004 | 02:10 PM
4drEF's Avatar
Keyboard Humorist
Most threads I have read that talk about the check valves seem to make it pretty common to run 2 or 3 check valves.
You said that you are getting a check light, but have you checked what code the ECU is throwing? If it's for the MAP sensor and you only get it during boost then it pretty much narrows it down to the check valves. I would suggest you add another in line with the one you have and see if that clears it up.
petty$rep
Honda Civic (2001 - 2005)
Jul 31, 2007 06:45 PM
Ponyboy
Jan 15, 2007 12:07 PM
DC2LsVtec
Jun 2, 2003 08:56 PM
Jspec_Imports
May 25, 2003 03:41 PM
W.Zero
May 1, 2003 01:33 PM
