Welding stainless steel...
Old Sep 27, 2004 | 12:11 PM
hatchback_al's Avatar
Default Welding stainless steel...
I was wondering what kind of wire and heat settings I should use for welding my t-304 stainless steel exhaust. I have never welded on this material before. Thanks.
Old Sep 27, 2004 | 02:17 PM
Ekasey's Avatar
Default Re: Welding stainless steel... (hatchback_al)
Are you Tig or Mig how thick is the material
Old Sep 27, 2004 | 07:33 PM
hillbillysi's Avatar
you have to tig it ... if you dont the metal that was weld'd on will no linger be stainless and will rust ... if that helps any ...
Old Sep 27, 2004 | 09:29 PM
Ekasey's Avatar
Default Re: Welding stainless steel... (hillbillysi)
you can use stainless filler wire
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hillbillysi &raquo;</TD></TR><TR><TD CLASS="quote">you have to tig it ... if you dont the metal that was weld'd on will no linger be stainless and will rust ... if that helps any ... </TD></TR></TABLE>
Old Sep 27, 2004 | 09:49 PM
Default Re: Welding stainless steel... (eLusive ek4)
I dont care if the welds rust, they are under the car. I have a wire feed MIG, its as thick as most exhausts my guess is .050
Old Sep 28, 2004 | 12:18 AM
tianporn's Avatar
Can you use an Arc welder to weld stainless steel 306 grade to mild steel? Eg. for a stainless muffler?
Old Sep 28, 2004 | 04:01 PM
Electron_LS-Vtec's Avatar
You want to put the welder on the low setting or lower than half so you dont blow holes in the material. I keep mine on about 4.5 on a scale to 10 when i weld thin wall stainless. I hope this helps.
Old Sep 28, 2004 | 05:05 PM
Default Re: Welding stainless steel... (Electron_LS-Vtec)
thanks, what about wire speed
Old Sep 28, 2004 | 05:35 PM
agrabau's Avatar
you'll have to play with the speed based on the gas and materials thickness. Use straight argon, 304 wire will work. Is this MIG or TIG?
(I assume MIG)
Old Sep 28, 2004 | 10:45 PM
Default Re: Welding stainless steel... (agrabau)
Yeah mig, i dont know what type of wire is in there now, how do i find out?
shawn69
Welding / Fabrication
Aug 3, 2008 02:29 AM
postman
16
May 20, 2008 10:08 PM
sleepystyle
Apr 1, 2006 09:24 PM
Want2race
21
Dec 19, 2005 05:44 PM
Bnjmn
Mar 6, 2004 08:34 AM
