b18a crank in b17 block
Old Sep 27, 2004 | 08:00 AM
TegRaceR98's Avatar
Default b18a crank in b17 block
crank fits i know that, but is deck height the same? so can it be done easily?
Old Sep 27, 2004 | 03:12 PM
TegRaceR98's Avatar
bump
Old Sep 27, 2004 | 03:51 PM
DOHCtorTHRUST's Avatar
Default Re: (TegRaceR98)
nope, the b17 deck height is the same as the b16(kinda like b16b = b18c). however it will work, if i recall i think it was omniman? that ran a ls crank with custom pistons that were really short...dont qoute me on that but i read it on here somewhere...
Old Sep 27, 2004 | 04:19 PM
TegRaceR98's Avatar
**** looks like im stuck with ls vtec again
Old Sep 27, 2004 | 04:48 PM
HONDABROMANDUDE's Avatar
you could use it with the tech43 kit, look it up
Old Sep 27, 2004 | 10:18 PM
TegRaceR98's Avatar
is it totally impossible, and if so what cranks other than b17's fit in this block correctly
Old Sep 28, 2004 | 12:08 AM
rjay8604's Avatar
yeah listen to him^. You can put a an 89mm crank with that setup.
Old Sep 28, 2004 | 11:06 AM
https://honda-tech.com/zerothread?id=815614
Old Sep 28, 2004 | 12:26 PM
TegRaceR98's Avatar
so just get those itty bitty pistons and im good? who can i contact about aquiring the 81.5mm pistons for this set up?
Old Sep 28, 2004 | 12:32 PM
WrongWD's Avatar
hmmm so with a b17 would this be a 2.0 motor?
Old Sep 28, 2004 | 01:55 PM
Kendall's Avatar
The B17 block is identical to the B16A block, with the only exception being the oil cooler. This being said, Tech43's piston kit will work just fine with the B17.
Old Sep 28, 2004 | 03:20 PM
StorminMatt's Avatar
Default Re: (WrongWD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WrongWD &raquo;</TD></TR><TR><TD CLASS="quote">hmmm so with a b17 would this be a 2.0 motor?</TD></TR></TABLE>
With an LS crank, 84mm pistons would give you 1972cc, 84.5mm pistons would give you 1996cc, and 85mm pistons would give you 2020cc. And, of course, this is independent of the block used. But if you are going to use this crank, I would not use a PR3 (B16A/B17A) block. The deck is really too short for so long a stroke. An LS or GSR block would be a better choice.
Old Sep 28, 2004 | 05:03 PM
contact member TECH43 RACING INC. That is his screenname, he has everything you will need for it.
Chugger
Mar 3, 2006 01:22 PM
JBBNJ609
11
Nov 11, 2004 11:40 AM
K20 EG
Jun 24, 2003 09:22 AM
scooter
Mar 4, 2003 11:05 PM
g2teg
Apr 8, 2002 03:38 PM
