Weird Brake booster Q
Old Sep 27, 2004 | 06:12 AM
stareatsun's Avatar
Default Weird Brake booster Q
I used seafoam recently and this is not a question about that.
After disconnecting the line from the booster to the IM and then reconnecting after i was done, is there any chance I damage the booster byn exposing it to atmosphere or jsut leaving it unpluged while the car was on?
I hit the brake and 90% of the time its perfect but then sometimes the pedal goes almost to the floor before i have any brake pressure?
my rear brakes are shot and i have had the abs light come on 2wice but that was when i started the car up. i shut it off and restarted and didnt have a problem.
This its the ABS, rear brakes or booster?
Old Sep 27, 2004 | 05:24 PM
stareatsun's Avatar
Anyone?
Old Sep 27, 2004 | 05:33 PM
Lord Helmet's Avatar
Default Re: Weird Brake booster Q (stareatsun)
could just be a faulty check valve that's goes between the hose and the brake booster.
Old Sep 27, 2004 | 05:51 PM
neu-era77's Avatar
Default Re: Weird Brake booster Q (sleeperciv)
most likely your brake master cylinder is going out!
mine started like that and now its getting worse!
but you did say, this start happening when you used seafoam and disconnect the hose, so it could be something else.
just letting you know, my one cent!!
Old Sep 27, 2004 | 06:12 PM
53JDMDC2's Avatar
first thing to do is replace the rear shoes and go from there. almost seems like moisture in the fluid. does the peddal do this after the breaks are hot ? when was the last time you replaced the fluid?
Old Sep 28, 2004 | 05:11 PM
53JDMDC2's Avatar
forget about the break fluid unless you have never changed it. I believe your problem is your master cylinder. the 10% of the time your peddal goes to the floor the master is bypassing the front breaks and is stopping with only the rears, that is why the rears are so worn. Change your master.
Old Sep 28, 2004 | 05:25 PM
53JDMDC2's Avatar
Default Re: (stareatsun)
bad boosters give you a hard peddal.
stevedefacto
Dec 25, 2011 06:04 AM
Cortez_h
Oct 27, 2010 06:48 AM
Fo-Do Fanatic
Aug 9, 2010 02:35 AM
joeherdda6
Dec 28, 2007 03:30 PM
dahoopdahup
May 2, 2006 03:29 PM
