ckf sensor interchangable?
Old Sep 26, 2004 | 11:34 PM
b20izzle's Avatar
Default ckf sensor interchangable?
Are ckf sensor interchangable between d series and b series?
Old Sep 27, 2004 | 04:03 AM
civic-4-ges's Avatar
Default Re: ckf sensor interchangable? (b20izzle)
I believe B-series are 3-wire, and that d-series are 2-wire
Anyone confirm??
Old Oct 5, 2004 | 03:41 PM
Slow_Em1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20izzle &raquo;</TD></TR><TR><TD CLASS="quote">Are ckf sensor interchangable between d series and b series?</TD></TR></TABLE>
dammit i have this code on a b16a2 in a 99 EX...where is it located?
Old Oct 6, 2004 | 09:23 AM
b20izzle's Avatar
Default Re: ckf sensor interchangable? (Slow_Em1)
i think above the oil filter
Old Oct 6, 2004 | 09:36 AM
Slow_Em1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20izzle &raquo;</TD></TR><TR><TD CLASS="quote">i think above the oil filter
</TD></TR></TABLE>thanks
Old Oct 6, 2004 | 09:54 AM
umm...CFK=Crank Fluctuation Sensor
Why would it be by the oil fiklter?? Unless you mean the plug, thats by the oil filter.
CFK sensor itself is behind your crank accessory drive pulley. It senses speed variations from the crank gear that drives your timing belt.
Old Oct 6, 2004 | 03:45 PM
b20izzle's Avatar
Default Re: ckf sensor interchangable? (civic-4-ges)
whoops didnt pay attention...i was talkin about the oil sensor....
Old Oct 9, 2004 | 04:23 AM
category5's Avatar
You'll see three wires that look like they come out of the oil pan right next to your crankshaft pully, that'll be your ckf sensor. Get that 400 ft/lb impact gun ready if your looking to change it! I believe the d and b motors are three wire. A green, white and black I believe on both.
Old Oct 9, 2004 | 06:12 AM
Default Re: ckf sensor interchangable? (category5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by category5 &raquo;</TD></TR><TR><TD CLASS="quote">I believe the d and b motors are three wire. </TD></TR></TABLE>
D is 2 wire
B is 3 wire
Old Oct 9, 2004 | 10:44 AM
b20izzle's Avatar
so where do i add the wire on the dx harness?
Old Oct 9, 2004 | 10:57 AM
There is a picture on H-T around here somewhere explaining it. I do not personally know
blkeg2
Aug 16, 2004 01:14 PM
vtecb20coupe
Jul 5, 2004 07:34 PM
integra-modder
Nov 12, 2003 10:24 PM
Jawad.
Jun 13, 2003 12:46 PM
b20ek
Apr 18, 2003 10:09 AM
