P73 ECU question
Old Sep 26, 2004 | 08:31 PM
KustomCrx's Avatar
Default P73 ECU question
What are the differences between the USDM P73, and the JDM P73? Any performance?
Old Sep 27, 2004 | 06:31 PM
KustomCrx's Avatar
Default Re: P73 ECU question (KustomCrx)
Does nobody know?????
Old Sep 27, 2004 | 07:19 PM
Jon D's Avatar
Performance......NO! As for differnces....it doesn't require the 2nd o2 sensor, is governed differently, and i am leaving something out which i forget right now. If you are considering purchasing one i would not recommend it. Why.....b/c you cannot comm with it using a scan-tool, and should your caR evaR need emissions testing they will fail it b/c they cannot comm with it. So instead of going thru the trouble of converting from jdm obd2 to usdm obd2...you had mise well go ahead and find youself a usdm p73. If anybody else knows what i am leaving out as far as the differences chime in....there is one if not maybe 2 more things. I know it also has the vtec swith built into the ecu and not on the solenoid.....hmmmm. Cant think of the other thing though!
Old Sep 27, 2004 | 09:27 PM
CNSK's Avatar
Default Re: P73 ECU question (B18C-Rsi)
00 teg has immbolizer..not sure bout jdm ......I have one though...usdm p73 ecu...pm me...
93h2beg
Engine Management and Tuning
Aug 14, 2010 10:11 AM
TahitianEG
Jul 17, 2007 12:35 PM
Parada
Nov 11, 2006 06:27 PM
error
Nov 2, 2005 01:22 PM
ptsiu
Nov 30, 2003 11:28 PM
