need help: can some body help me with aligning my headlights?
hi
I was wondering if someone could tell me how to align my headlights for the G3 Integra, I just got front body work done and changed my bulbs. Both headlights seem to be a little too low and to the side. Pics would be nice if anyone had any.
Thanks
Thanks
open up the hood and u should see a little dial, it is white colored dial and you wont miss it if u are changing your bulbs...or is this dial for left and right only?! worth a try...
umm i think there's 2 on each side.... one is by the high beam side and the other is rite bbetween the lowbeam and fenders.. get a 4 head screwdriver and twist.. but the manual says get a full tank of gas.. get on level ground and then adjust to wat you want it to be.. cuz mine are all fucked up too.. can't do much about mine so i just leave it. ohh and rite.. one of them is for horizontal and the other is vertical alignment.
[Modified by MyKarsNameIsMichelle, 7:32 PM 12/12/2001]
Really, if you want to align your headlights right, you should take it to a good shop with an electronic headlight aligner. I've tried to adjust them myself and only made it worse.
I should just get a phillips screwdriver and twist? I tried but nothing moved. I asked Acura and they said they were going to charge me $75CDN to align it! Does it really require that much time and effort? Maybe I should just take it to a shop.
