RSX steering wheel fit integra?
i did a search about it and all i found was one guy saying it will fit an integra... i got a 94 LS and if anyone else knows for sure that it will id apreciate it cause i have no idea whatsoever thanks
JDM CTR will not fit.
None of the SRS air bags will plug in since your SRS system is from the OBD1 generation. All the SRS plugs changed in the OBD2 system. So no plug and play for you. However you can still use it w/o an active air bag.
Hey . what about the new si ? will it fit on Teg? My friend just installed the new SI steering wheel on his 95 Hatch and I think the teg is pretty much the same.
<U></U>
BUY MY STUFFS
2 Alpine 12 Subs with box $ 250 less than 3months,
one pair integra front seat $ 150 ( tan leather) still good
AEM short ram $ 45 ( red) for Ls
clear front bumper corner lights $ 15
94 Ls cluster 11k $ 40
Left and Ritght dark green fenders with S 2000 stanley sidemarkers $ 100
<U></U>
BUY MY STUFFS
the JDM EP3 ones will bolt in and wire up to a OBD2 SRS system.
However the USDM version will bolt in but not wire up.
Your only chice for working SRS is the wheel you have or a 92-95 Civic one with a H on the airbag.
No other SRS system will work on the OBD1 system unless you rewire the system or the bad. AS you know if you blow up the bag during rewiring is could take you head off and kill you instantly. Only rewire if you know exactly what your doing and have all the safety tools.
its not that i dont like the one i got... mine is messed up so i figured id get a new one and i like the stockish look on wheels i dont like aftermarket wheels so i wanted to see if something else would fit....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by akhom »</TD></TR><TR><TD CLASS="quote">AS you know if you blow up the bag during rewiring is could take you head off and kill you instantly. Only rewire if you know exactly what your doing and have all the safety tools.</TD></TR></TABLE>
Well, obviously you don't disconnect your battery when doing wiring.
LOL.....
I was actually interested in the same about putting in an rsx wheel in my DC2 because i wanted something different but still more stock. I seeing that you can use the EK steering column and then use the RSX wheel, Im sure there is already some genious out there who has already made an adapter harness to do the swap.. Do some research on it and let everyone know what you find, ill be doing the same.
LOL.....
Do you see how old this thread is?
-slow ej-
May 14, 2007 09:47 PM
sys3rror
Sep 16, 2003 08:56 PM
