Question about Type RX pedals
Old Sep 26, 2004 | 06:23 PM
NiceDc2r's Avatar
Default Question about Type RX pedals
Is the Type RX pedals a direct bolt in to USDM ITR...Is there any benifit to them or is it just bling...I hope the are actually a little bit closer together than the USDM pedal assembly
Here is a referance pic
Old Sep 26, 2004 | 06:30 PM
Curt941's Avatar
Default Re: Question about Type RX pedals (NiceDc2r)
There was a thread about them somewhere on here. I remember reading that the brake pedal assembly won't work because it's for RHD cars...the person just unriveted the cover and riveted it onto the stock brake pedal assembly...
Old Sep 26, 2004 | 06:33 PM
Ketone's Avatar
They are not a direct bolt in. The clutch pedal and the gas pedal bolt in, but you have to modify the brake pedal. One option is to cut the current brake pedal off the usdm brake arm, and welded the new brake pedal(from the jdm brake arm) in its place. I think it is just for "bling" in my opinion.
Old Sep 26, 2004 | 08:02 PM
white rocket's Avatar
Default Re: Question about Type RX pedals (Curt941)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Curt941 &raquo;</TD></TR><TR><TD CLASS="quote">There was a thread about them somewhere on here. I remember reading that the brake pedal assembly won't work because it's for RHD cars...the person just unriveted the cover and riveted it onto the stock brake pedal assembly...</TD></TR></TABLE>
That person was me. Yeah it was an expensive venture. Basically your paying for pedal covers that rivot on. It's bling but they're dope IMO. I didn't even use the arms that came with them.
Old Sep 27, 2004 | 01:46 AM
1993sir05's Avatar
i thought they were the same as the usdm. just on the right side of the floor.
Old Sep 27, 2004 | 07:37 AM
PY 01-0972's Avatar
Default Re: Question about Type RX pedals (1993sir05)
correct me if I am wrong but those look like the dc5 pedals the dc2 rx pedals could and can be bought as a pedal cover that I believe you screw on.
wrinkly
Oct 5, 2009 07:50 AM
LtBernie
Sep 21, 2009 05:00 AM
no1knows908
Mar 6, 2008 04:13 AM
