Problems with down shifting?
Old Sep 26, 2004 | 05:22 PM
B-Hatchie's Avatar
Default Problems with down shifting?
Hi Im new to the fourm and so far its kick a$$. But anyway, i put a ACT clutch in my car(Xtreme pressure plate with 6 puck disc) and it wont down shift into third until the rpms drop and its sometimes hard to down shift into second. Other then that its fine. It up shifts like a champ( grabs like a ****). Any answers?
Old Sep 28, 2004 | 10:53 AM
B-Hatchie's Avatar
Default Re: Problems with down shifting? (B-Hatchie)
Noboby has any ideas? Laim
Old Sep 28, 2004 | 02:22 PM
doublejz's Avatar
are you match revving when down shifting? it not give that a shot. My act used to do that, but mysteriously stopped
Old Sep 29, 2004 | 06:04 AM
B-Hatchie's Avatar
Default Re: Problems with down shifting? (doublejz)
Call me dumb, but what is match revving? How long did it last for you?
Old Sep 29, 2004 | 10:12 AM
gunnis's Avatar
Rev matching is raising the rpms while downshifting, so they match what the rpms were at before you started changing gears.
so driving in 4th at 60mph say at 4000 rpm,clutch in a little gas to hit 4000rpm again while going into 3rd gear. let the clutch out and get on that gas.
I'm sure theres a way better example but i just simplified it, thats the basics of it. good luck
Old Sep 29, 2004 | 10:55 AM
please.laugh's Avatar
Default Re: Problems with down shifting? (gunnis)
^^^ not quite, if your in fourth gear going at 4000rpms, and you shift down to third, assume your going to be at 6-6500rpm. So, while you push in the clutch and move the leaver from fourth to third, you simultaniously rev the engine from 4000rpm to 6-6500rpm and then you let out the clutch just as you reach the rpm you THINK you'll be at. Get to know your car. This helps by NOT slipping the clutch and puts less stress on your transmission!! Good to do.
BTW-this is where you'll really notice throttle response loss typical with a cai.
Old Sep 29, 2004 | 11:42 AM
B-Hatchie's Avatar
Default Re: Problems with down shifting? (please.laugh)
Oh ok, Thats the only way i can down shift unless i wait for it to go down to about 2000-2500 rpms.
Old Sep 29, 2004 | 03:20 PM
Humble1's Avatar
you really dont need to do all that match rev stuff. thats why sncyros are there for.
Old Oct 1, 2004 | 09:47 AM
doublejz's Avatar
Default Re: Problems with down shifting? (Humble1)
are you having any problems upshifting? If you took the slave cylinder off you could have air in the lines not allowing you to disengage/engage the clutch completely. My clutch had emotion break downs for like the first 300 miles, then it was fine. I'm guessing it just need to break in.
Old Oct 1, 2004 | 12:04 PM
B-Hatchie's Avatar
Hey doublejz not tryin to be an a** but read the last sentence my friend
Old Oct 1, 2004 | 03:31 PM
Redsun's Avatar
Heel + Toe, works wonders.
Old Oct 2, 2004 | 08:46 AM
doublejz's Avatar
Default Re: (Redsun)
my bad
Old Oct 2, 2004 | 09:23 AM
B-Hatchie's Avatar
Default Re: (doublejz)
No biggie brother
Old Oct 2, 2004 | 12:52 PM
eg6T's Avatar
Default Re: (B-Hatchie)
with my act 6 puck i have to match rev or it wont go into gear..i dont really suggest downshifting into second ever since i did and snapped an axle...
Ef4doorwagon
Nov 28, 2014 10:17 PM
Outkast95LS
Apr 8, 2008 12:31 AM
ateeb786
Nov 6, 2006 07:15 PM
EJ8chu
Oct 27, 2005 05:32 AM
weakGOODJunKieS.com
May 8, 2003 06:14 AM
