brake lines?
Old Sep 26, 2004 | 03:24 PM
ammob16's Avatar
IYAAYAS
Default brake lines?
Im in the process of stripping down the interior of my hatch. There are some olive colored "hard-lines" that run along the bottom of the driver and passenger side doors and across where the back seat was. Are they brake lines or am I wrong? Also my car leans heavily to the drivers side, it bugs the hell out of me. It rides smooth and has perfect alignment so I dont even know where to look. As far as I know the suspension is all O.E. Thanks in advance
Old Sep 26, 2004 | 04:27 PM
elmalouno's Avatar
Default Re: brake lines? (ammob16)
how much do u weigh big guy?
Old Sep 26, 2004 | 04:39 PM
ammob16's Avatar
IYAAYAS
Default Re: brake lines? (elmalouno)
I weigh 206-218, but it leans even when I am not in the car.....so I like to eat......big deal.
Old Sep 26, 2004 | 05:17 PM
type Gendy's Avatar
hahah
Maybe its like a mattress, after sleeping in it a while it sorta stays indented in the middle...er wherever u sleep.
So maybe your car is just staying with that g@ngsta l3an!
Old Sep 26, 2004 | 05:19 PM
Muckman's Avatar
Moderator in Chief
Maybe you bent or broke something.
Old Sep 26, 2004 | 05:23 PM
Super79Dave's Avatar
Yes the ones along the back of the seats are brake lines. the ones going down the drivers side are fuel lines.
Super79Dave
Old Sep 26, 2004 | 08:51 PM
travis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ammob16 &raquo;</TD></TR><TR><TD CLASS="quote">Im in the process of stripping down the interior of my hatch. There are some olive colored "hard-lines" that run along the bottom of the driver and passenger side doors and across where the back seat was. Are they brake lines or am I wrong? Also my car leans heavily to the drivers side, it bugs the hell out of me. It rides smooth and has perfect alignment so I dont even know where to look. As far as I know the suspension is all O.E. Thanks in advance</TD></TR></TABLE>
If you are able to do the work yourself, you could remove the springs and compare the height. If they are the same, you can swap them L/R and see if anything changes. Old, OEM stuff gets worn. The dampers shouldn't effect the static position of your springs unless they are siezed. Beyond the springs, I would be surprised if the rubber bushings could produce a lean that you could actually see without measurement, but I guess it's possible. Have you actually measured the ride height on both sides (you can do it at the jack points) to see what the difference is?
Old Sep 27, 2004 | 02:42 PM
ammob16's Avatar
IYAAYAS
never actually thought of measuring under the car, I've only noticed it in the wheel-wells. Looks like the passenger rear is jacked up while the front driver is lowered. Its about a half inch difference on each side as far as fendergaps go.
Shutweld
May 3, 2018 07:13 PM
MugenEg
Suspension & Brakes
10
Jan 18, 2013 08:18 AM
thompson4908
Jun 6, 2011 05:56 AM
Acoupdetat
Aug 15, 2004 11:39 AM
