Honda S2000 Honda S2000
S2K when hitting V-TEC it screws up......
Old Sep 26, 2004 | 03:23 PM
Officer's Avatar
Default S2K when hitting V-TEC it screws up......
My bosses S2K, when it hits V-tec it sounds like it start hopping all the way up through v-tec to redline. Just wondering what might cause that and how could I fix it. Thanks
Old Sep 26, 2004 | 07:05 PM
GradyDC5's Avatar
Check the oil level.... My old hatch did something similar to what you are describing.. Pop in and out of vtec b/c of low oil.
Old Sep 27, 2004 | 06:56 AM
Mr. Bagel's Avatar
Default Re: S2K when hitting V-TEC it screws up...... (TotaledHatch)
Any more details on the actual issue?
Is he letting it warm up to 3 bars?
Oil level, as previously mentioned, checked?
Old Sep 27, 2004 | 12:37 PM
PNB's Avatar
PNB
GatorNATION
Default Re: S2K when hitting V-TEC it screws up...... (Mr. Bagel)
I don't think this can be stressed enough: vtec. Not v-tec, not v-tech, not v-t3K..
Old Sep 27, 2004 | 02:10 PM
EMiranda's Avatar
Your boss's VTEC must be ****.
Tell him to buy this:
Your can get it at your nearest 7/11 It increases at least 120hp if u shove it into ur glove box
Old Sep 27, 2004 | 06:54 PM
Officer's Avatar
Default Re: S2K when hitting V-TEC it screws up...... (Airman1038)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PNB &raquo;</TD></TR><TR><TD CLASS="quote">I don't think this can be stressed enough: vtec. Not v-tec, not v-tech, not v-t3K..</TD></TR></TABLE>
Sorry to be a dick but i will type v-tec, vtec, V-tech, v-t3k however the **** i want to so dont correct me on it....Thank you to everyone that has gave me useful info. Sorry i dont have anymore info on him warming it up or anything. he just told me about it and i thought i might ask you all, but anyways thanks
Old Sep 27, 2004 | 09:15 PM
Kenso's Avatar
HT White Ops
Default Re: (ReallySlowEg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ReallySlowEg &raquo;</TD></TR><TR><TD CLASS="quote">Check the oil level.... My old hatch did something similar to what you are describing.. Pop in and out of vtec b/c of low oil.</TD></TR></TABLE>
Sounds like oil level problem.
Old Sep 27, 2004 | 09:28 PM
VTECorona's Avatar
Default Re: (Kenso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kenso &raquo;</TD></TR><TR><TD CLASS="quote">
Sounds like oil level problem.</TD></TR></TABLE>
I agree since the F20C is known to burn oil, it even says to expect it in the owners manual. This also means that he may have not gotten an oil change in a long while since he should only be burning about a quart within 3000 miles. Tell him to check his oil every 2-3 weeks or so to be safe, even though the manual says to check at every gas fillup.
Old Sep 28, 2004 | 11:20 AM
.Chris.'s Avatar
Default Re: (VTECorona)
Car could also be missing due to poor/incorrectly gapped plugs. This happened to an ITR I was looking at. Kid didn't know what the issue was. We pulled plugs and re gapped them. It didn't miss anymore.
It could also be your rotor (do S2k's have a rotor?)
Old Sep 28, 2004 | 11:24 AM
cmdr430's Avatar
Default Re: (Black204GSR)
i would also say oil level related....
no cel right?
maybe some sort of limp mode
there is no rotor/ distributor on s2k... individual coil on each wire
Old Sep 28, 2004 | 11:26 AM
.Chris.'s Avatar
Default Re: (cmdr430)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cmdr430 &raquo;</TD></TR><TR><TD CLASS="quote">i would also say oil level related....
no cel right?
there is no rotor/ distributor on s2k... individual coil on each wire </TD></TR></TABLE>
Possibly plugs then. I had an oil level problem on my old GSR and it threw a cel.
Old Sep 28, 2004 | 04:04 PM
Razor's Avatar
either oil level or the map sensor is acting up. try re-installing the map sensor, it's very easy to do.
Old Sep 28, 2004 | 11:37 PM
evil vapor's Avatar
Default Re: (Razor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Razor &raquo;</TD></TR><TR><TD CLASS="quote">either oil level or the map sensor is acting up. try re-installing the map sensor, it's very easy to do.</TD></TR></TABLE>
No need to reinstall the map, just tap it gently. It's near impossible to diagnose your bosses car on the internet. Did you drive it hard and he pressed you to fix it or something Make sure the car is current on maintenance and TSB's. That is easy to check with your local honda dealer.
Old Sep 29, 2004 | 04:28 AM
Jet Phi's Avatar
seems like oil prob to me
Old Sep 29, 2004 | 05:21 PM
DaZman69's Avatar
Default Re: S2K when hitting V-TEC it screws up...... (Phi)
you'll probably only throw a cell if your oil pressure is crazy low, when mine is low and I go around a turn it drops to like idle oil pressure low, which is not enough to engauge vtec. If your cel comes on because of oil pressure, you have a serious problem.
Old Sep 29, 2004 | 07:19 PM
Officer's Avatar
Default Re: S2K when hitting V-TEC it screws up...... (DaZman69)
I thank you all for your info on this and i talked to him today at work and he said that it quit doing it...Honestly i dont know, which all he does is starts it and drive it, and complains to me when **** gets broken. but anyways thanks
92H23VTEC
Nov 25, 2007 06:49 PM
JSpekBB4
Oct 30, 2007 10:23 PM
SiR99
Jan 7, 2007 10:10 PM
MrRealityman
Apr 28, 2006 08:16 AM
Master23
Jul 8, 2004 10:25 AM
