timing quest.
Old Sep 26, 2004 | 06:53 AM
53JDMDC2's Avatar
Default timing quest.
I crashed my teg and in doing so it cracked my distributor. Found another one, stabed it in and cant find how to set the timing. Do I need to jump any terminals together, or do I just hook up my timing light and set it. Also what should the timing be on a stock 98 ls motor. I read 16 deg+/- 2.
Old Sep 26, 2004 | 09:52 AM
AllMotorGSR94's Avatar
1. Get car up to normal operating temp
2. jump the service connector. should be in a green holder under the glove box.
3. loosen distributor slightly (enough to move back and forth)
4. Hook up the timing gun to #1 cylinder plug wire.
5. while running aim timing light at crank pulley (should be a piece of plastic stickin out indicating TDC on lower timing cover)
6. Move distributor back and forth to you find your timing spot. I think 16 is stock but while you there might as well bump it to 18.
7. Once set tighten everything back up. recheck timing.
Old Sep 26, 2004 | 10:11 AM
Lord Helmet's Avatar
Default Re: (AllMotorGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AllMotorGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">1. Get car up to normal operating temp
I agree except for #6, I wouldn't advance it unless I had a cam to actually benefit from it.
Old Sep 26, 2004 | 10:26 AM
W.O.P.'s Avatar
Default Re: (sleeperciv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleeperciv &raquo;</TD></TR><TR><TD CLASS="quote">
I agree except for #6, I wouldn't advance it unless I had a cam to actually benefit from it. </TD></TR></TABLE> i agree. UNLESS your running N20
Old Sep 26, 2004 | 11:58 AM
53JDMDC2's Avatar
is the service connector the same connector you pull codes from? if so jump # what to # what.
Old Sep 26, 2004 | 05:19 PM
yea now that i think about it, keep the timing stock. Im used to dealing with built motor so excuse me
yea its the same connector you pulled codes from. all you need is a paper clip. just connect the two ports together
Old Sep 26, 2004 | 07:58 PM
53JDMDC2's Avatar
thanx for the advice. the connector was in a green case on the pass kick panel w/ only 2 pins you could jump. timed car , runs great.
Old Sep 30, 2004 | 12:13 PM
imdrax's Avatar
im trying to do my timing right now and i have a chiltons but when i use my timing light i dont see any marks that are red or white? does anyone have a picture of where the spot your supposed to point the light at is?
Old Sep 30, 2004 | 03:39 PM
Default Re: (imdrax)
Old Oct 1, 2004 | 05:05 PM
imdrax's Avatar
Old Oct 1, 2004 | 10:27 PM
boosted k20's Avatar
look at picture in above post!
u need to connect the timing light to cpark plug wire # 1. poit it like in the above pic: at the crank pulley
allnaturalb16
21
Aug 14, 2007 08:57 PM
miksew
Jun 7, 2006 08:03 AM
rice a roni
Aug 25, 2005 07:17 AM
3rdGteg
Dec 1, 2002 08:15 AM
yakkosmurf
Dec 24, 2001 08:08 AM
