Jum cams on order, what kind of valves should I get?
Old Sep 26, 2004 | 06:45 AM
VSBB6's Avatar
Default Jum cams on order, what kind of valves should I get?
I have placed an order for Jun cams, valvesprings & retainers.
Now what kind of valves should I get to go with the setup? Choices are: Ferrea, Endyne or Skunk2.
Thanks!
Old Sep 26, 2004 | 07:08 AM
92hondalude's Avatar
Default Re: Jum cams on order, what kind of valves should I get? (VSBB6)
skunk2
Old Sep 26, 2004 | 08:17 AM
H22Power_521's Avatar
skunk2
Old Sep 26, 2004 | 08:30 AM
p3t312's Avatar
Default Re: (H22Power_521)
skunk 2 baby
Old Sep 26, 2004 | 08:57 AM
Shakes's Avatar
space cadet
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by p3t312 &raquo;</TD></TR><TR><TD CLASS="quote">skunk 2 baby </TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22Power_521 &raquo;</TD></TR><TR><TD CLASS="quote">skunk2</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92hondalude &raquo;</TD></TR><TR><TD CLASS="quote">skunk2 </TD></TR></TABLE>
Are you ******* serious?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VSBB6 &raquo;</TD></TR><TR><TD CLASS="quote">I have placed an order for Jun cams, valvesprings & retainers.
Thanks!</TD></TR></TABLE>
ENDYN, Ferrea, Skunk2 in that order. no exceptions.
Old Sep 26, 2004 | 10:25 AM
flip1199's Avatar
Default Re: Jum cams on order, what kind of valves should I get? (Shakes)
you guys are forgetting some of the major players like REV and supertech.
Old Sep 26, 2004 | 11:33 AM
98TypeSH's Avatar
Default Re: Jum cams on order, what kind of valves should I get? (flip1199)
dude, what happened to OEM valves???
i dont see a reason in getting different valves unless you got higher comp pistons and thin *** head gasket.
Old Sep 26, 2004 | 11:50 AM
ludermark's Avatar
Default Re: Jum cams on order, what kind of valves should I get? (98TypeSH)
if I got the jun h22a camshafts and just plan on installing the cams, do I need upgraded valvetrain at all? thanks, oh and whats the whp gained from tuned jun cams with bolt ons? 20 whp ?
thanks.
Old Sep 26, 2004 | 01:18 PM
VSBB6's Avatar
Good point, is OEM valves good enough for the extra lift?
Ive seen too many cases where the cams and valves broke from crower cams, makes me think twice before acquiring Jun cams.
BTW, do you have aftermarket ECU? All I have is VAFC.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98TypeSH &raquo;</TD></TR><TR><TD CLASS="quote">dude, what happened to OEM valves???
i dont see a reason in getting different valves unless you got higher comp pistons and thin *** head gasket.</TD></TR></TABLE>
Old Sep 26, 2004 | 02:17 PM
satan_srv's Avatar
Vast majority of cam failures are due to improper installation.
Stock Valves are fine, I would recommend them
Old Sep 26, 2004 | 08:24 PM
VSBB6's Avatar
Default Re: Jum cams on order, what kind of valves should I get? (satan_srv)
My motor has 100k, is it worthwhile to replace with brand new OEM valves?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by satan_srv &raquo;</TD></TR><TR><TD CLASS="quote">Vast majority of cam failures are due to improper installation.
Stock Valves are fine, I would recommend them</TD></TR></TABLE>
Old Sep 26, 2004 | 09:11 PM
precord96's Avatar
you should be fine.
Oem valves work just fine, and the extra 15 or so dollars x 16 doesn't justify the need.
Old Sep 26, 2004 | 10:46 PM
98TypeSH's Avatar
Default Re: Jum cams on order, what kind of valves should I get? (precord96)
i got OEM valves of jun cams and so on.
WHy would my computer matter as to what valves im using?? lol but to answer your question i have a p72 with hondata.
Old Sep 26, 2004 | 10:48 PM
SpanishRicer's Avatar
I've heard of improper installation ruining a good set of cams as well. Something about not modifying the rocker arms to run aftermarket cams leads to premature valvetrain failure? Can someone clarify this?
Old Sep 27, 2004 | 06:21 AM
VSBB6's Avatar
Some ppl said Jun cams would not perform well with stock ECU, I was wondering if thats true.
As for the cam gears, what kind of settings are you using to run Jun cams?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98TypeSH &raquo;</TD></TR><TR><TD CLASS="quote">i got OEM valves of jun cams and so on.
WHy would my computer matter as to what valves im using?? lol but to answer your question i have a p72 with hondata.</TD></TR></TABLE>
Old Sep 27, 2004 | 08:08 AM
98TypeSH's Avatar
im on 00 on the stock cam gears. Havent gotten around to getting cam gears, should probably do that but im in no rush. Car is currently in the body shop getting minor dings and scratches taken out.
No way i would run jun cams on a stock computer. Some people swear by using a p13 and using a VAFC but id much rather have a more controlable program, hence why i went hondata.
Old Sep 27, 2004 | 08:29 AM
BolivianFuego's Avatar
Sounds like your ATTS then isnt functioning anymore i take it?
Old Sep 27, 2004 | 10:35 AM
VSBB6's Avatar
I drive a Sportshift so there isn't any ecu option for besides VAFC. Is this adequate to make use of the Jun parts for the time being?
I may go with EFI PMS as my standalone option in the future.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98TypeSH &raquo;</TD></TR><TR><TD CLASS="quote">im on 00 on the stock cam gears. Havent gotten around to getting cam gears, should probably do that but im in no rush. Car is currently in the body shop getting minor dings and scratches taken out.
No way i would run jun cams on a stock computer. Some people swear by using a p13 and using a VAFC but id much rather have a more controlable program, hence why i went hondata.</TD></TR></TABLE>
Old Sep 27, 2004 | 10:44 AM
98TypeSH's Avatar
You are correct Bolivian, atts went out the window. want it ? lol
Old Sep 27, 2004 | 10:54 AM
No thanks the added weight is not needed for what im trying to achieve.
Old Sep 27, 2004 | 10:58 AM
H22Si's Avatar
check out SI Industries valves. awesome price and quality. i know quite a few people who have used them with no problems to date. if anything i'd at least go with some s.s. exhaust valves and some stock intakes.
http://www.sivalves.com/ocforeign_valves.html
$11.50 ea. for their swirlpolished racing valves. intake & exhaust
Modified by H22Si at 3:40 PM 9/27/2004
EZ$$EF
17
Nov 11, 2007 04:07 PM
red civic standard
14
Jan 6, 2005 09:33 AM
jeffk182
Oct 25, 2004 03:57 PM
01DC-2
16
Jun 6, 2004 05:48 AM
ITRFetish2000
May 18, 2004 08:26 AM
