Please help a fellow hybrider
Old Dec 11, 2001 | 09:37 PM
Frosty_spl's Avatar
Default Please help a fellow hybrider
crap, i havent had my vtec working sence march, the solinoid clicks when you hardwire it, i redid the solinoid wire, and still dosnet work. oh yea, i just got done swaping heads because i thought something might be clogged in there, IT STILL DOSENT WORK! why is this so? yes there is enough oil in it. if the oil pressure switch is bad, it will throw a code right? NO codes. ecu is ok too, i tested it on my friends car. Please help!
Old Dec 12, 2001 | 10:23 AM
Lsos's Avatar
Default Re: Please help a fellow hybrider (Frosty_siR)
Do you have your speedo working?
[Modified by Lsos, 7:23 PM 12/12/2001]
Old Dec 12, 2001 | 10:28 AM
Katman's Avatar
yeah did you check the basics..
- speedo sensor
- oil temp sensor
- is the vtec solenoid grounded?
- try changing the solenoids?
- avoid the noid?
Old Dec 12, 2001 | 12:05 PM
Frosty_spl's Avatar
Default Re: Please help a fellow hybrider (Katman)
my speedo works, where is the sensor?
oil temp sensor, is that the one on the back of the block? i changed that.
there is one wire going to the solinoid. is there suppose to be 2?
im gonna try to change the solinoid and pressure switch this weekend.
noid? as in dominos pizza?
thanx!
Old Dec 12, 2001 | 12:11 PM
fowler!'s Avatar
VSS is on the back of the tranny, sticks up a little bit.
Old Dec 12, 2001 | 07:44 PM
Frosty_spl's Avatar
Default Re: Please help a fellow hybrider (fowler)
the vss has the gear on the inside right? is it a pain to swap out? if it didnt work, would my speedo work?
[Modified by Frosty_siR, 8:50 PM 12/12/2001]
Old Dec 13, 2001 | 08:57 AM
Frosty_spl's Avatar
another guy said it might be the knock sensor, but it would throw a code right?
Old Dec 14, 2001 | 12:08 AM
paulzy's Avatar
you'll still get vtec even if the knock was fucked up, I did...test the oil pressure going to the solenoid...
jump the ecu for codes even you don't have a CEL...sometimes they don't wanna show up(that's what happened to my friend). He had two codes pop up, but no CEL
[Modified by Slow_ass_4dr, 1:09 AM 12/14/2001]
jdubEP3
Jan 26, 2012 05:23 AM
$amGD3
15
Apr 14, 2010 05:53 PM
vladd
Jul 10, 2008 05:03 PM
obuhmyuh
Feb 24, 2008 08:20 PM
Snail Tuning
Oct 21, 2004 08:16 PM
