Please help for the love of god!
crap, i havent had my vtec working sence march, the solinoid clicks when you hardwire it, i redid the solinoid wire, and still dosnet work. oh yea, i just got done swaping heads because i thought something might be clogged in there, IT STILL DOSENT WORK! why is this so? yes there is enough oil in it. if the oil pressure switch is bad, it will throw a code right? NO codes. ecu is ok too, i tested it on my friends car. Please help!
How do you know that Vtec is not working? Try a different solenoid and pressure switch. Just to eliminate it from your list of things that could be bad.
i know it dosent work because it dosent pull much harder and the sound dosent change much instead of baaaaaaAAAAAAA is like baaaaAaaaaaa. HEHE, im gonna swap solinoids and pressure switches with my friend, see if that dosent work. thanks, oh yea i only ran a 15.3 when i should run mid 15's.
hmm do you have enough oil in it,what about having a bad knock sensor. if you haev a knock it wont engage vtec and if you dont have the right oil levels you aint got enough pressure to lock those valves...
DoHc-
10
Nov 10, 2014 01:02 AM
Travis R
Jul 23, 2011 02:06 PM
