need belt help
Old Sep 26, 2004 | 12:51 AM
GOTNOS's Avatar
Default need belt help
i recently droped a h22a into my 92 si and wnet ahead and used my h23 powersterring pump and alternator well i for got they both have aem pullys.
I went to honda and napa and both gave me the same belts which are a lil small they both need to be a tad bit longer can anyone help me figure out what belt i need to order thanks.
Old Sep 26, 2004 | 05:49 AM
GOTNOS's Avatar
Default Re: need belt help (GOTNOS)
anyone know?
Old Sep 26, 2004 | 10:23 AM
SKDRCR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GOTNOS &raquo;</TD></TR><TR><TD CLASS="quote">i recently droped a h22a into my 92 si and wnet ahead and used my h23 powersterring pump and alternator well i for got they both have aem pullys.
I went to honda and napa and both gave me the same belts which are a lil small they both need to be a tad bit longer can anyone help me figure out what belt i need to order thanks.</TD></TR></TABLE>
If you are using the aem pulleys that were originally on your h23,
the alternator pulley won't work because the h23 one has 5 ribs and
your h22 crank pulley has 6 ribs.
You either need to swap alternator pulleys or put the h22 alternator on.
If you're not running ac, the napa part # for the alternator belt is 25-060370
Old Sep 26, 2004 | 10:26 AM
LudeyKrus's Avatar
I did basically the same thing. I used the H23 accessory pulleys on my H23 VTEC that was dropped in.
I ended up having to put the H23 crank pulley on, and use the factory-length power steering belt and an alternator belt that was .5" longer than factory, IIRC.
BTW, the only place that I could find that had the right size belt for the alternator was NAPA.
Old Sep 26, 2004 | 02:10 PM
Skidtron89's Avatar
Default Re: need belt help (SKDRCR)
Just because teh alternator has a 5 rib belt and the H22 has a six doesn't mean you can't just run a 5 ribbed longer belt and just not use the 6th rib.
The belts should have come with the pulleys anyways so what the problem?
Just go get a slightly longer belt and take it back till you get the correct size. Might be two trips or so if your poor. If you have some money go get like 3-4 different lengeths and then take back the ones you don't need.
Old Sep 26, 2004 | 02:21 PM
GOTNOS's Avatar
Default Re: need belt help (Skidtron89)
yea the rib thing isnt a issue really but the problem is these pulley where on my h23 so they have been used and i no longer have the belts. Should i call AEM dealers and see if they have some h23 belts? for the pulleys....
oSrBo
Mar 20, 2013 06:54 AM
1_SIK_EG2
May 5, 2010 03:18 PM
Infinity_Racer
Jan 14, 2008 09:02 PM
Grenade2k7
Jun 26, 2007 03:58 PM
Sick'Lude
Dec 7, 2004 10:41 AM
