Question oN draining..
Took The head off.... Doing a minime.. somehow.. coolant/oil got in the cylinder walls..
Need to Drain The block.. Searched alrdy found 1 Drain Plug On the exhaust side.. Is this the only 1?
Thanks D15z1 Block
Thanks D15z1 Block
Yes...
Near the oil filter - left upper side if you look from drivers point of view... you cannot miss it...
Don't forget to take off the radiator cap to let all the coolant out...
Also drain your oil if you haven't already, cos it might be contaminated with coolant
skunk2finatic
Dec 16, 2004 02:46 PM
