d15b2 block + d16y7 head = d16y7 tbelt??? and what water pump?
i found out the hard way tonight that the d15b2 timing belt is a little bit too long. it skipped teeth and my valves made not so nice noises.
I hope i didn't bend any.
anyway, i've read that y7 and y8 t-belts are the same thing, and that when you use a y8 head on a EF block you have to use the y8 tbelt. i'm assuming i need to get a y7 tbelt so which i also assume will be shorter (less teeth) than the d15b2 timing belt.
since i took the time to take the crank pulley off, and timing cover, and since i'm about to get a new tbelt, i figured i might as well get a new water pump while i'm at it. do i just get a replacement d15b2 water pump or do i need one for a d16y7?
TIA for your help.
-T
I hope i didn't bend any.anyway, i've read that y7 and y8 t-belts are the same thing, and that when you use a y8 head on a EF block you have to use the y8 tbelt. i'm assuming i need to get a y7 tbelt so which i also assume will be shorter (less teeth) than the d15b2 timing belt.
TIA for your help.
-T
From: the asshole of america..., upstate new york, USA
wow, i would have guessed that the d15 t-belt would actually be shorter than the d16 because of the shorter deck height. hmmm.
but ive never compared them before.... im not sure - bump
I have a Y7 head with b7 block. Using z6/y8/y7 T-belt. Use the 1.5 water pump.
BTW I doubt you bent valves, I jumped a couple teeth on a 11:1 comp y8 head/b7 block combo and they were fine. And my camgear slipped once and no bent valves.
Btw I like this setup, boosting it next week.
CivicxTree754
Nov 15, 2011 01:23 AM
Red_ED8
Apr 14, 2008 06:03 AM
hb_guy
Jan 26, 2006 06:04 PM
