Selling my Z28 to build a RWD K24 type S Integra!
OK guys heres your chance to take over a longtime project in the making CHEAP!!!
I have decided to sell everything!
93 Z28 chassis full interior...
95 LT1 fully built 1000hp race ready 383 setup for big turbo or blower: (motor is fully assembled and still on the engine stand with 0 time!).
Forged 4 bolt splayed mains.
Cola forged crank.
Custom JE 8.5:1 forged pistons.
Total Seal gapless rings.
6" Manley Pro Mod style rods ARP 2000 bolts. (Speed O Motive brand)
Custom ground blower cam.
Cloyes infinately adj. billet timing set.
210CC LT4 AFR heads fully worked by AFR. (about 223ccs now per AFR)
Fully ported LT4 intake.
Modded, polished fuel rails with AN fittings
58mm BBK throttle body.
Comp Cams Hi-Tech SS 1.5 true roller rockers.
Comp Cams push rods.
Fel Pro gaskets.
Clevite bearings.
ARP mains, head, oil pump, etc. stud kit.
Melling Hi volume high psi oil pump.
New OEM oil pan tapped for oil return.
OEM oil cooler.
Custom B&B valve covers with breathers.
High volume Mezeire electric water pump (there are 2 versions, mines the higher volume of the 2).
A/C delete kit.
Forged keyed crank hub.
One of a kind custom fully adjustable cam sensor for individual coil packs.
Front bumper cover heavily modded for front mount intercooler Very nice!
4 new 255-50-16s BFG TAs on like new 16x8 BBS wheels.
Rear tubular lower control arms (dont remember the brand).
RK Sport console gauge pod.
New in box polyurethane kit.
Extra entire engine cradle/subframe with suspension, brakes, rack, etc.
New American Sportscar Design cowl induction hood.
Have stock hood too.
Extra set of tailights.
Car is black with grey interior... the entire engine compartment has been stripped and painted a beautiful "sparkle silver" and is ready for reassembly.
You will get all the hardware, stock 95Z28 ECU, wire harness (uncut!), radiator, condensor, fans, brackets, accessories, most everything but a tranny! Lots of extra misc. parts go with it... (stock piston, rods, crank, extra steering colum, and lots more!)
Over $35k invested...
Make reasonable offer, I have plenty of pictures, receipts, etc. or come see it in person.
Listing on Ebay too.
Selling seperately:
Still in box Pro Fab chromeoly K member setup for pinto rack
like new MSD 6AL
MSD BTM
Brand new Accel DFI 6 for LT1 (harness, ecu, sensors, everything!)
Brand new sealed MSD 50# injectors
4L80E tranny that needs rebuilding
New SCE copper headgaskets
Like new Nologly coil
Used Accel super coil
Taylor 10mm wires (one needs to be repaired, got to close to a header on one end)
'93 Z28 yellow instrument panel and interior switches
Like new Sequential Speed Pro ECU, wideband O2, data cable, software (will fit any application, just send it to F.A.S.T. for your application... I was quoted $65)
40hp 125cc shifter kart in mint condition 0-100mph 6 secs. 2.5Gs !!!
89 650 Kawasaki stand up jetski with new HP engine and mods.
See a preview at http://www.hughlett.net/mycar.html
Blower has been sold...
Please email me for more details or to ask a question...
Randy
Cola forged crank.
Fel Pro gaskets.
Clevite bearings.
OEM oil cooler.
A/C delete kit.
Selling seperately:
like new MSD 6AL
MSD BTM
Randy
x still jaded x
Sep 7, 2010 04:05 PM
JDMJNKY
Mar 20, 2007 10:56 PM
