Headlight Problem?
Old Sep 25, 2004 | 08:03 PM
808civic808's Avatar
Default Headlight Problem?
Recently I had a problem with my running lights with my 95 honda civic and headlight so I thought they were all interconnected somehow. I thought that my low light was out so I bought a new light and it still doesn't work. Both my highlights work but my low light doesn't. Any suggestions to what it could be. I also checked both of my headlight fuses.
Old Sep 25, 2004 | 08:07 PM
95sihb's Avatar
Default Re: Headlight Problem? (808civic808)
Check the plug......specifically the wires that go into the plug .Sometimes the wire corrode( like mine ) and sometimes the wire are pushed out ,or pulled out.
Old Sep 25, 2004 | 08:36 PM
TallAssFilipino's Avatar
Default Re: Headlight Problem? (95sihb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95sihb &raquo;</TD></TR><TR><TD CLASS="quote">Check the plug......specifically the wires that go into the plug .Sometimes the wire corrode( like mine ) and sometimes the wire are pushed out ,or pulled out. </TD></TR></TABLE>
Yeah, on my Si, the harnes plug that plugs to the back of the bulb behind the headlamp corroded over time and from heat. It always slipped out especially after hard takes-off's or hard shifting.
flipside1212
Lighting
Jun 3, 2009 01:44 PM
EM2Thrasher
Honda Civic (2001 - 2005)
May 10, 2006 06:29 PM
PhantomX
Sep 15, 2005 10:44 AM
coot_er
Sep 12, 2004 08:27 PM
ebp 99 si
13
Jun 3, 2004 11:20 AM
