wavering idle. changed some stuff, code 15. i'm stumped!
Old Sep 25, 2004 | 07:10 PM
carnifex's Avatar
Default wavering idle. changed some stuff, code 15, then no codes. i'm stumped!
i was getting code 15 and 16. (searched archives) i changed the injectors out, replaced the main relay (per link to about.com), and changed ecu's. same codes on the new ecu to start with. today it started stalling and losing power a mile from the house. code 15 this time. took it home. reset ecu aand checked volts at dizzy. all good. now it runs ok but i am still gettting high/wavering idle with no codes. should i carry a spare dist? where should i look for a short? should i just run new power wires to the dist through the firewall? i am getting tired of thei breaking down crap! thanks for all of the help.
Old Sep 25, 2004 | 07:41 PM
jlicrx's Avatar
Default Re: wavering idle. changed some stuff, code 15, then no codes. i'm stumped! (carnifex)
sounds to me like you need a new igniter in the distributor
Bagged_em1
Oct 31, 2016 06:09 PM
ketchup214
Apr 17, 2010 03:03 PM
wokamanbizness
Jan 18, 2009 10:35 AM
EJ2-Fluffy
Aug 30, 2005 03:45 PM
wrXtian
Feb 7, 2003 06:40 PM
