Clutch and Flywheel Combos - Awesome pricing!
Pro Street Online offers you our new Pro Street Clutch and Flywheel combos! We combine our Pro Street 8lb lightweight racing flywheels with Exedy's stage 1 organic clutch kits to bring you the best deal around!
When replacing your clutch, you MUST have your old flywheel either resurfaced or replaced to ensure proper contact and even wear during break-in. Your flywheel must be resurfaced by a machine shop to your applications specs. This resurfacing process can cost anywhere from 80-100 dollars when properly done. Why resurface your old flywheel, when you can replace it and upgrade at the same time! For just a little bit more, you can have a SFI approved lightweight flywheel to go with your clutch when its time to replace it.
Save by purchasing both items together!
Click here to order: Clutch and Flywheel Combo
In stock and ready to ship!
The driveability will be like a stock clutch. Pedal efforts will be higher because of the higher clamp loads. All of these clutch discs have high capacity spring center dampers to reduce the drive train shock and impact.
Pro Street Lighweight Aluminum Flywheel Specs:
Super lighter weight equals faster acceleration.
Reduce turbo lag.
Gain more mid-range for ALL MOTOR engines.
6061-T6 aircraft grade billet aluminum.
Billet Aluminum Flywheels meet SFI Spec 1.1 or 1.2
Weights 8lbs
Acura CL 1997 PSCB02 $409.99 Trim: 2.2L F22B1 Specs: Exedy Organic Clutch (08805) and Pro Street 8lb Flywheel
Acura Integra 1990 - 1991 PSCB07 $429.99 Trim: B18A1 Specs: Exedy Organic Clutch (08804) and Pro Street 8lb Flywheel
Acura Integra 1992 - 1993 PSCB08 $429.99 Trim: B17A / B18A Specs: Exedy Organic Clutch (08800A) and Pro Street 8lb Flywheel
Acura Integra 1994 - 2001 PSCB01 $399.99 Trim: B Series Specs: Exedy Organic Clutch (08800B) and Pro Street 8lb Flywheel
Honda Accord 1990 - 1997 PSCB02 $409.99 Trim: 2.2L F22 Specs: Exedy Organic Clutch (08805) and Pro Street 8lb Flywheel
Honda Accord 1990 - 2002 PSCB02 $409.99 Trim: 2.3L F22 Specs: Exedy Organic Clutch (08805) and Pro Street 8lb Flywheel
Honda Civic 1988 PSCB04 $399.99 Trim: 1.5L D15 Specs: Exedy Organic Clutch (08802) and Pro Street 8lb Flywheel
Honda Civic 1988 PSCB04 $399.99 Trim: 1.5L D15 Wagon Specs: Exedy Organic Clutch (08802) and Pro Street 8lb Flywheel
Honda Civic 1989 PSCB05 $399.99 Trim: 1.5L D15 Specs: Exedy Organic Clutch (08803) and Pro Street 8lb Flywheel
Honda Civic 1989 PSCB05 $399.99 Trim: 1.5L D15 Wagon Specs: Exedy Organic Clutch (08803) and Pro Street 8lb Flywheel
Honda Civic 1990 - 1991 PSCB06 $399.99 Trim: 1.5L D15 Specs: Exedy Organic Clutch (08801b) and Pro Street 8lb Flywheel
Honda Civic 1990 - 1991 PSCB06 $399.99 Trim: 1.6L D16 Specs: Exedy Organic Clutch (08801b) and Pro Street 8lb Flywheel
Honda Civic 1990 - 1991 PSCB06 $399.99 Trim: 1.5L D15 Wagon Specs: Exedy Organic Clutch (08801b) and Pro Street 8lb Flywheel
Honda Civic 1992 - 1995 PSCB03 $394.99 Trim: 1.5L D15 Specs: Exedy Organic Clutch (08801A) and Pro Street 8lb Flywheel
Honda Civic 1992 - 2000 PSCB03 $394.99 Trim: 1.6L D16 Specs: Exedy Organic Clutch (08801A) and Pro Street 8lb Flywheel
Honda Civic 1999 - 2000 PSCB01 $399.99 Trim: Si B Series Specs: Exedy Organic Clutch (08800B) and Pro Street 8lb Flywheel
Honda Civic 2001 - 2004 PSCB03 $394.99 Trim: 1.7L D17 Specs: Exedy Organic Clutch (08801A) and Pro Street 8lb Flywheel
Honda CRX 1988 PSCB04 $399.99 Trim: 1.5L D15 Specs: Exedy Organic Clutch (08802) and Pro Street 8lb Flywheel
Honda CRX 1988 PSCB04 $399.99 Trim: 1.6L D16 Specs: Exedy Organic Clutch (08802) and Pro Street 8lb Flywheel
Honda CRX 1990 - 1991 PSCB06 $399.99 Trim: 1.5L D15 Specs: Exedy Organic Clutch (08801b) and Pro Street 8lb Flywheel
Honda CRX 1990 - 1991 PSCB06 $399.99 Trim: 1.6L D16 Specs: Exedy Organic Clutch (08801b) and Pro Street 8lb Flywheel
Honda Del Sol 1993 - 1995 PSCB03 $394.99 Trim: D15/D16 1.5 or 1.6L Specs: Exedy Organic Clutch (08801A) and Pro Street 8lb Flywheel
Honda Del Sol 1994 - 1997 PSCB01 $399.99 Trim: B Series Specs: Exedy Organic Clutch (08800B) and Pro Street 8lb Flywheel
Honda Del Sol 1996 - 1997 PSCB03 $394.99 Trim: D16 1.6L Specs: Exedy Organic Clutch (08801A) and Pro Street 8lb Flywheel
Honda Prelude 1991 - 2001 PSCB02 $409.99 Trim: 2.2L F22 Specs: Exedy Organic Clutch (08805) and Pro Street 8lb Flywheel
Honda Prelude 1991 - 2001 PSCB02 $409.99 Trim: 2.2L H22 Specs: Exedy Organic Clutch (08805) and Pro Street 8lb Flywheel
Honda Prelude 1992 - 1996 PSCB02 $409.99 Trim: 2.3L H23 Specs: Exedy Organic Clutch (08805) and Pro Street 8lb Flywheel
