resetting tdc question
Do I have to remove the crank pulley to get to the timing belt tensioner? My belt is off a tooth or so, and I just need to set the cam gear to tdc, then get the timing belt off the cam gear so I can set the crank pulley to tdc.
No, you dont have to remove the crank pulley.
There is a plug in the lower timing belt cover. Pull it out and you will see the 14mm bolt for the tensioner.
*Edit- Luserkid beat me to it.
wk9k
Mar 13, 2012 05:45 PM
JDM_SOHC
27
Sep 28, 2009 09:05 AM
LoudLude
Jan 31, 2006 05:21 PM
