Building a B18c Turbo... opinions...
Old Sep 25, 2004 | 02:14 PM
95DXPhiladeph's Avatar
Default Building a B18c Turbo... opinions...
Okay, so I'm incredibly happy with the power my car is putting out with a B18c, limited slip, the cold air intake, and full 2.5" exhaust...
Now I'm looking to get this thing up to around 300 whp... or atleast 315.... so like 280ish at the wheels at the LEAST
I know I'll have to drop the block out of it and go with some new internals... JE pistons and eagle H beam connecting rods... then some ARP rod bolts... is there anything else you would do while you were down there and had the chance?
I plan to piece together a turbo, I was wondering if anyone knew a list of everything I would need.
I am running a stock p72 manual JDM computer right now...
People tell me to get my comp chipped and run Hondata or something similar with this turbo...
Here's my list so far...
JE Pistons
Eagle Rods
ARP Rod Bolts
Turbo
Blow off Valve
Wastegate
New oil pan (mines dented)
Injectors (440cc)??
Intercooler and piping
what else?
Old Sep 25, 2004 | 02:25 PM
Default Re: Building a B18c Turbo... opinions... (95DXPhiladeph)
tippity top
Old Sep 25, 2004 | 02:36 PM
Jimmy's Avatar
Global Moderator
Reason why your not getting replies is because you need to go to the forced induction forum..
Old Sep 25, 2004 | 02:39 PM
spyderracing's Avatar
Default Re: (Jimmy)
http://www.cse.uconn.edu/~yele....html
tells you everything you need to know about piecing together a turbo kit.
Old Sep 25, 2004 | 02:41 PM
The Mista Mike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95DXPhiladeph &raquo;</TD></TR><TR><TD CLASS="quote">
JE Pistons
Eagle Rods
ARP Rod Bolts
Turbo
Blow off Valve
Wastegate
Injectors (440cc)??
what else?</TD></TR></TABLE>
Starting all the way on the bottom...
Oil Lines and fittings
Check your valves for wear and tighten everything up
Manifold gasket (change it to be safe)
Turbo manifold
Wastegate piping
Downpipe
Adapter plate (as needed)
Lots of misc. nuts and bolts
Air filter or window mesh
Lots of clamps
Intercooler for that type of set up
FMU or some type of fuel flow enhancer
Injectors (as needed)
Fuel Pump (as needed)
And you're set to go. I don't think I left anything out.
Old Sep 26, 2004 | 01:06 AM
replies like these is why i love this place....
THANKS!
turbopanda
Dec 4, 2002 01:10 AM
turbopanda
Sep 16, 2002 12:11 PM
Blown90hatcH
Jul 7, 2001 01:24 PM
