92 acura vigor help please
I'm preparing to do an obd0 to obd 1 conversion on my 88 hatch.
Went to the junkyard looking for gray obd 1 plugs. Found a 92 acura vigor. I got the feul injectior plugs. Didn't have enough tools to get to the o2 sensor, dizzy plug, and ecu.
I noticed it was an inline 5. So now i'm thinking the dizzy plug might not work.
Here's what i'd like to know.
1. What size are the injectors? I guess they're at least 240 cc.
2. Does this car have a 4 wire o2 sensor?
3. I believe the dizzy is against the firewall on the passenger side. The engine bay is a clusterfuck. Where is this connector?
BTW I searched, 26 results came up. The injector question has been asked before. Nobody replied. Went to acura on the way home, they didn't know anything.
Thanks
Thanks
Went home and got more tools.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kenso »</TD></TR><TR><TD CLASS="quote">There is no connector on the vigor distributor. The cam/crank/tdc sensors are on the front of the motor triggered by the cam gear.</TD></TR></TABLE> That explains why i didn't see any wires and was like WTF
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by simplyredvw »</TD></TR><TR><TD CLASS="quote">I'll answer #2.
Yes, that Vigor has a 4 wire O2 sensor.
Yep, found it by the right front tire.
Anybody know about the injectors?
I got the o2 sensor, ecu plugs off a pv1 ecu, and all gray plugs off the engine for $10. It was a good day.
Thanks
</TD></TR></TABLE>Yep, found it by the right front tire.
Thanks
killerpenguin21
May 9, 2010 05:07 PM
