Color code for power antenna turn on lead.......
Old Dec 11, 2001 | 06:40 PM
MestizoRacer310's Avatar
Default Color code for power antenna turn on lead.......
I need it for an external switch.......please let me know what color it is and where i can find it...........thanks
Old Dec 12, 2001 | 03:41 AM
urbanlegend21's Avatar
New User
Default Re: Color code for power antenna turn on lead....... (TeamDynasty91AccordEX)
a simple Haynes manual will give you a wiring diagram for this check it out, I don't know which it is on your generation
Old Dec 12, 2001 | 09:34 AM
4doorH22's Avatar
If I recally correctly, there are only 3 leads going into the antenna. Trial and error dude...
I think the way I did it was to disconnet and reconnect one wire at a time with the radio on until the mast went down.
Old Dec 12, 2001 | 10:08 AM
DeJaVu's Avatar
Default Re: Color code for power antenna turn on lead....... (4doorH22)
I have 5th gen, but try this. Open the plastic cover on the back and see if you have yellow/white wire. You should have this wire also on the front near your h/u. If you have a multimeter, test on the white/blue wire. This is the wire that connected to your fuse and relay and hot all the times (constant 12V).
Hope that helps ....
[Modified by DeJaVoE, 7:09 PM 12/12/2001]
xunkn0vvnx
Audio / Security / Video
Jan 26, 2017 11:57 PM
98civhatch
Jul 5, 2009 05:58 PM
super civic
Honda Civic (2006 - 2015)
Oct 9, 2008 07:48 AM
99delsol
Sep 13, 2006 09:09 PM
PearlWhiteAccord
Jun 18, 2002 05:17 AM
