SAFC wiring question
i'm in the middle of hooking it up for a friend, but in the wiring instructions it doesn't say what wire goes to the throttle signal pin-out of the ecu. on the diagram of the ecu in the instructions it shows the ground, power, rpm signal, pressure signal, and throttle signal pin-outs, but on the diagram on what wire from the safc goes to which pin it doesn't show a wire going to the throttle signal. Is it suppose to hooked up to one of the wires or not?? How would the safc read if the throttle is open or not and also the voltage of the TPS??
kholmes
Jul 21, 2004 09:29 AM
