need help tranny pops out of fifth gear
Old Sep 25, 2004 | 05:09 AM
rizq777's Avatar
Default need help tranny pops out of fifth gear
when im driving in 5th gear after the about 30 seconds it pops out of gear what could be the problem. also i started noticing that when im driving if i hold on to the shifter i feel and erratic vibration happen every other minute. what could be my problem.
Old Sep 25, 2004 | 05:37 AM
snatch's Avatar
Default Re: need help tranny pops out of fifth gear (rizq777)
Transmissions popping out of gear can commonly be shift forks that are bent or about to break.
Old Sep 25, 2004 | 06:03 AM
PyroProblem's Avatar
Default Re: need help tranny pops out of fifth gear (******)
top off your trans fluid. Sounds like its low.Ive seen this a hundred times including my own car.
Old Sep 25, 2004 | 06:34 AM
RICE POLICE SIP's Avatar
Default Re: need help tranny pops out of fifth gear (PyroProblem)
Popping out of gear..... I'de say your sincros.... Give it a little while and it will start to pop out of 4th then 3rd.... so on and so on...
Old Sep 25, 2004 | 06:48 AM
dinosa21's Avatar
Default Re: need help tranny pops out of fifth gear (Split Image Prez)
Have you added any thing new to the car (short shifter,bushings) Check all the bolts on the shift linkage.
Old Sep 25, 2004 | 07:03 AM
FLCivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PyroProblem &raquo;</TD></TR><TR><TD CLASS="quote">top off your trans fluid. Sounds like its low.Ive seen this a hundred times including my own car.</TD></TR></TABLE>
yeah this happend to me too, found out that I had no tranny fluid. I filled it up with Honda MTF and the problem was fixed.
Old Sep 25, 2004 | 07:57 AM
rizq777's Avatar
thanx im gonna check it out
Cohgarrr13
Honda Civic (2001 - 2005)
Jan 8, 2018 05:05 PM
Nate13
24
Jul 9, 2010 08:19 AM
lumnite
Dec 9, 2009 06:29 PM
Wazup
Oct 25, 2007 02:47 PM
wrx'n you
Dec 21, 2005 08:20 AM
