my mechanic said "ACT 6 puck is too harsh"
Old Sep 24, 2004 | 11:36 PM
Pee Wee's Avatar
Default my mechanic said "ACT 6 puck is too harsh"
I have to replce my transmission and i got a good deal on a 90 si, but i have an 88 so i needed to buy a new clutch and flywheel.
I got the Fidanza 7.5lb flywheel and I want to get the 6 puck because someone is going to hook me up on the price.
Ive already been driving around with an ACT stage 2 so how much harsher could it get?
Old Sep 24, 2004 | 11:40 PM
oldB18EF's Avatar
Default Re: my mechanic said "ACT 6 puck is too harsh" (opey'scrx)
its pretty damn harsh...but youll get used to it after a while.
It definitely sucks for stop and go traffic
Old Sep 24, 2004 | 11:45 PM
Pee Wee's Avatar
Default Re: my mechanic said "ACT 6 puck is too harsh" (Project D)
that what i thought?
any downsides?
oldB18EF's Avatar
it works fine i have no complaints using the ACT 8lb flywheel with it
Old Sep 24, 2004 | 11:48 PM
Pee Wee's Avatar
Default Re: my mechanic said "ACT 6 puck is too harsh" (mrspeaker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrspeaker &raquo;</TD></TR><TR><TD CLASS="quote">Ur calf is gonna be big as hell....
It feels the same as a semi-truck's clutch</TD></TR></TABLE>
so im guessing its hard as hell to engage
Old Sep 24, 2004 | 11:52 PM
EL Vap133's Avatar
I heard you can damage your tranny with one.
Old Sep 24, 2004 | 11:53 PM
Pee Wee's Avatar
thanks for the info mrspeaker
im going to say **** him and buy it anyway.
Old Sep 24, 2004 | 11:56 PM
hahagasdcrx's Avatar
look forward to repacing your tranny again soon.......
Pee Wee's Avatar
Default Re: my mechanic said "ACT 6 puck is too harsh" (EL Vap133)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">I heard you can damage your tranny with one. </TD></TR></TABLE>
what kind of damage
Old Sep 24, 2004 | 11:57 PM
importboi22's Avatar
Default Re: my mechanic said "ACT 6 puck is too harsh" (hahagasdcrx)
too many people hopped on the stupid 6puck wagon..... there is something called overclutching you car..... you dont need an ACT hdpp with 6puck if you got a single cam with i/h/e. your just gonna make your car slower
Old Sep 24, 2004 | 11:59 PM
Loaded Butane's Avatar
I can kill a tranny on a stock clutch. Who needs a 6 puck?
When I did have a 6 puck I didnt kill a tranny from it. I had the 6 puck on my 88 tranny and when it started grinding to bad I put a newer tranny in it.
Old Sep 25, 2004 | 12:28 AM
davens's Avatar
Do you need a 6 puck clutch? You don't mention your setup anywhere...
Man, a 7.5lb flywheel AND a six puck....that things going to be like an on/off switch. Whether that's good or not depends on what you're using the car for.
A 6 puck's harsh engagement does but more stress on the tranny...I imagine the input shaft bearing and the diff would rather you use something else.
I could see a 6 puck on a high mileage, loose tranny as hurrying the inevitable...
Old Sep 25, 2004 | 12:46 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrspeaker &raquo;</TD></TR><TR><TD CLASS="quote">Ive seen mounts break cuz of how strongly the clutch engages ..but ive never seen internal damage of tranny from them......
someone explain.. </TD></TR></TABLE>
ive seen input shaft bearings go out from them, also seen 2 differetials strip out because of them. Ive also seen 1 tranny with damage to the gears from a unsprung 6 puck.
Old Sep 25, 2004 | 12:49 AM
biggdogg's Avatar
Default Re: (davens)
your also gonna wear out that flywheel quick too. the harsh engagement will eat the disc up fast . trust me i use a street strip disc with a stg 2 pp and it works great and feels like stock . not to mention im probably close to 200 whp on my poormans typeR. trust me you dont need it . its just a fad that everyone hopped on to feel better about themselves . no they`re trannies hate them for it .
Old Sep 25, 2004 | 06:37 AM
Jo-Tek Concepts's Avatar
Default Re: (biggdogg)
I used a stock Flywheel lightened and balanced to 12lbs and a ACT 6 puck disc with a stock pressure plate..........I tore my tranny case and mount within 2 weeks!!! This was with a Dohc ZC and Si Tranny.
it is harsh but the engagement I experienced was very quick, I could damn near sit at a stop sign in 1st gear idling. Traffic was a bitch too, I can't reiterate that anymore!!! Rush Hour traffic + 6 puck =
Old Sep 25, 2004 | 07:16 AM
sd.coupe's Avatar
I had a ACT 6 Puc and it was Gnarly........ super shitting for everyday driving.... but if your racing it's a must have!
Old Sep 25, 2004 | 07:36 AM
Pee Wee's Avatar
Default Re: (sdhatch)
maybe i should reconsider? but $200 is damn cheap
Old Sep 25, 2004 | 08:38 AM
hondaguyef's Avatar
Default Re: (opey'scrx)
Is it sprung or unsprung? I had a sprung 6 puck and I got used to it after a while. I did change it out for a full face though. 6 pucks aren't needed unless you are frying full face discs constantly IMHO!
Phil
Old Sep 25, 2004 | 08:41 AM
BiG Chris's Avatar
in my last rex which was a dx i used a 6puck disck with no springs and the damage that it did was snap the bold in the front motor mount. In my new rex i dont think im going that way im prolly only going to go with a 2 maybe 3 stage clutch from act. but like you said 200 is too cheap to pass up
Old Sep 25, 2004 | 08:55 AM
RCautoworks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by opey’scrx &raquo;</TD></TR><TR><TD CLASS="quote">that what i thought?
any downsides? </TD></TR></TABLE>
Yep, things can end up broken. Do a little searching around and you will see.
Modified by 90blackcrx at 2:37 PM 9/25/2004
Old Sep 25, 2004 | 09:11 AM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: my mechanic said "ACT 6 puck is too harsh" (90blackcrx)
also with such a heavy pedal pressure you can snap the pedals i busted mine with a freakind CM stage1 and 8lb flywheel!
Old Sep 25, 2004 | 09:26 AM
kid-honda's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">
Yep, thinks can end up broken. Do a little searching around and you will see. </TD></TR></TABLE>
I know a guy who bought a 00 Si brand new and its on its 3rd tranny at 28k miles with a 6 puck and its not a race car.
Old Sep 25, 2004 | 09:28 AM
xtrafastcivic's Avatar
Default Re: my mechanic said "ACT 6 puck is too harsh" (Ace$nyper)
wow IMO i think a lot of people talk out of their ***... i'm using a 4 puck right now but i've used a 6 puck for a good 5 years on cable and hydro trannies.. havent broke anything... launch on slicks more times then i can count.. you cant blame it all on the clutch.. it is harsh for the intake header exhaust my car is fast type guys but if you're going to use it for what it is for then buy it ... and 200 is a damn good price.. new that is..
Old Sep 25, 2004 | 09:32 AM
kid-honda's Avatar
Default Re: my mechanic said "ACT 6 puck is too harsh" (XtraFastCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XtraFastCRX &raquo;</TD></TR><TR><TD CLASS="quote">wow IMO i think a lot of people talk out of their ***... i'm using a 4 puck right now but i've used a 6 puck for a good 5 years on cable and hydro trannies.. havent broke anything... launch on slicks more times then i can count.. you cant blame it all on the clutch.. it is harsh for the intake header exhaust my car is fast type guys but if you're going to use it for what it is for then buy it ... and 200 is a damn good price.. new that is.. </TD></TR></TABLE>
I agree to a point.
Half the problem is the owner but its still harder on the driveline so even with proper use it will strain the driveline.
Old Sep 25, 2004 | 10:30 AM
Default Re: my mechanic said "ACT 6 puck is too harsh" (kid-honda)
i agree but .. using racing parts and/or any part you have to maintenance them.. it's not a stock honda that is going to last 10 years 300k miles with no oil changes... you have to maintenance everything
