i am gettin wheel hop at the track what should i do?
Old Dec 11, 2001 | 05:59 PM
f1nal zeros's Avatar
Default i am gettin wheel hop at the track what should i do?
when i went to th track this past week i was gettin bad wheel hop off the line. i first reved it to 5000rpm and then let it go and i hopped bad, almost as if i had hydrolics..lol. so i thought maybe i should launch lower, so i launched at 3000rpm and still got bad wheel hop. i dont have the stock tires. i have faken aziens and i lowered the pressure to 25 instead of the 40 they have in them. i tried both ways once with full pressure and then with 25 pressure. what should i do? should i lower the pressure more? should i leave the pressure? or should i get whole new suspension?
mando
02' pearl white RSX type S
Old Dec 11, 2001 | 06:41 PM
NostraDEIMOS's Avatar
Default Re: i am gettin wheel hop at the track what should i do? (f1nal zeros)
the tire pressure isn't your problem...i think 25 is just right...what you need to work on is your driving...not trying to be mean...you're getting off your clutch WAY too fast...you need to ease off it, but don't ease off too slow...i say rev it up to 3500-4000 and then ease off the cluth and ease on the gas quickly...don't dump the clutch...b/t/w...wheel hop is bad for your car...it can loosen your engine and transmission mounts which you don't want to happen...just a though
-ralph
Old Dec 12, 2001 | 07:51 PM
EG8R's Avatar
Default Re: i am gettin wheel hop at the track what should i do? (NostraDEIMOS)
Slowly let out the clutch? He'll have no clutch left.... heh oh wells
Old Dec 12, 2001 | 08:06 PM
Cold Chunker's Avatar
Do a road course instead of a drag strip!
Works for me!
Old Dec 13, 2001 | 08:06 AM
taZman~RSX-S's Avatar
Default Re: i am gettin wheel hop at the track what should i do? (mr. skelly)
Dumping the clutch will get him no further along either and actually do more damage over time..
Practice bro...You need a smooth transition...
Old Dec 13, 2001 | 04:31 PM
 fast[R]'s Avatar
Default Re: i am gettin wheel hop at the track what should i do? (taZman~RSX-S)
I had the same problem at the trak, you need to lower your tire presure to 15 and doo a nyce burn befor the run, works good for me.
Old Dec 30, 2001 | 05:13 PM
2002integra-S's Avatar
New User
Default Re: i am gettin wheel hop at the track what should i do? (fastR)
you should lower the presurre to somewhere around 15... i also agree.... along with a great burnout.... and not popping the clutch you should have a nice run...i pulled a 14.8 completely stock....all i did was open the air box thats it...I have an rsx type s by the way...and if driven right man this car halls ***
green98civic
Honda Motorcycles
Jun 2, 2004 12:28 PM
bOOsTiNSoHcVtEc
Oct 12, 2003 08:44 PM
ShaDoWbOi
Jul 11, 2003 05:58 AM
Ideal
Oct 5, 2002 07:00 PM
ActiveAero
Sep 7, 2001 09:50 PM
