H4H HID
Old Sep 24, 2004 | 09:48 PM
G2ILS's Avatar
Default H4H HID
Hello guy I'm looking for a HID kit for my JDM one piece but I can't fine any. The kits that I find are for h4. I'm actually looking for a 1200k purple HID kit for a H4H. Were can I get one?
Old Sep 24, 2004 | 09:50 PM
thaiphob's Avatar
Nikon!!!
Default Re: H4H HID (G2ILS)
they dont make kits for H4H. did you make apost about this like 2 days ago?
Old Sep 24, 2004 | 09:55 PM
G2ILS's Avatar
Default Re: H4H HID (thaiphob)
I did but I was just looking for the name of the bulb cause i didn't now it. My brother got me the h4 bulb but it was to big. theres anyway i can convert it from h4 to h4h?
Old Sep 24, 2004 | 10:02 PM
G2ILS's Avatar
come on guys I wanna now if I can convert an HID light bulb from a H4 to an H4H.
Old Sep 24, 2004 | 10:18 PM
TunerN00b's Avatar
Ok, a couple of things about that. But first, please tell me this car will never be driven on the road.
1) putting a HID bulb in a reflector based headlight is bad bad bad. It creates a ton of glare. Its blinding for other drivers. Its illegal. Its dangerous.
2) 12000K (assuming you meant that, 1200K isn't even on a normal range there) is not even possible with HID bulbs. There are some kits that claim it, but most aren't really 12000K, or if they are, they would be so dim, it will be less light than an incandescent bulb, much less a halogen like what you have now.
3) 4000K - 5000K is white daylight. 4200K is what BMW, Mercedes, and every other car with factory HID use. 6000K is nice and blue, but dimmer. Anything over that is usually a colored bulb, less light. The bluer the light, the more glare, the more haze. Its a higher frequency, and the light "bleeds" out to be glare for oncomming traffic. 8000K HID creates so much glare, that even in HID projectors, you still blind oncomming traffic, even if its aimed right.
If you want that nice blue/purple twinkle the BMW, Audi, etc. have, you will need to retrofit some HID projectors into your housings, and run a proper (not rebased) bulb. If you want more color, then bend the cutoff closer, and your color banding will increase. Their headlights are pure WHITE, not blue, but they have a colored cutoff from light refraction. But please, stop with these dim, ugly, unsafe, illegal, cheap *** blue color HID bulbs in not HID headlights.
Old Sep 24, 2004 | 11:41 PM
G2ILS's Avatar
Default Re: H4H HID (TunerN00b)
okay lets say I got an HID kit with an H4 bulb can I convert it to an jdm H4H bulb.
Old Sep 24, 2004 | 11:51 PM
importdude2000's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G2ILS &raquo;</TD></TR><TR><TD CLASS="quote">okay lets say I got an HID kit with an H4 bulb can I convert it to an jdm H4H bulb.</TD></TR></TABLE>
u can shave the h4 hid kit to fit the hole in jdm 1peices
but again it will blind other peeps..
just go with polarg 4300k bulbs
or retrofit projectors in~!
Old Sep 24, 2004 | 11:57 PM
thaiphob's Avatar
Nikon!!!
Default Re: H4H HID (importdude2000)
get some silverstars from autozone.
Old Sep 25, 2004 | 12:01 AM
G2ILS's Avatar
how can I shave them, cause the jdm is way smaller in size at the circle that attache it to the headlight
Old Sep 25, 2004 | 01:42 AM
TunerN00b's Avatar
Unless this is for a show car ONLY, don't put HID lights in a reflector.
If it is for show, and will not be driven, then go buy the cheapest autozone, pepboys, etc. h4 bulb you an find ($4.99) and butcher the thing until it fits, and you'll know what to do with the real HID capsule and won't mess them up on a first attempt.
For a street car, retro some projectors.
Modified by TunerN00b at 3:23 AM 9/25/2004
Old Sep 25, 2004 | 05:08 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TunerN00b &raquo;</TD></TR><TR><TD CLASS="quote">3) 4000K - 5000K is white daylight. 4200K is what BMW, Mercedes, and every other car with factory HID use. 6000K is nice and blue, but dimmer. Anything over that is usually a colored bulb, less light. The bluer the light, the more glare, the more haze. Its a higher frequency, and the light "bleeds" out to be glare for oncomming traffic. 8000K HID creates so much glare, that even in HID projectors, you still blind oncomming traffic, even if its aimed right.
well color temperature is not going to make a difference on how much glare there is, at least when a projector housing is concerned. The beam pattern and cutoff is determined by the geometry of the reflector, lens, bulb position, and shield position. Increasing the color temp isn't going to change how much light escapes above the cutoff or how sharp the cutoff is.
But I agree, anything other than OEM 4300K is retarded. And OMG 12000K how ghey is that, that's like ultraviolet blacklight color temp. Yeah, let's give everyone a tan and burn their retinas as we drive down the road at night.
Old Sep 25, 2004 | 01:07 PM
TunerN00b's Avatar
Default Re: H4H HID (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">well color temperature is not going to make a difference on how much glare there is, at least when a projector housing is concerned. The beam pattern and cutoff is determined by the geometry of the reflector, lens, bulb position, and shield position. Increasing the color temp isn't going to change how much light escapes above the cutoff or how sharp the cutoff is.
But I agree, anything other than OEM 4300K is retarded. And OMG 12000K how ghey is that, that's like ultraviolet blacklight color temp. Yeah, let's give everyone a tan and burn their retinas as we drive down the road at night. </TD></TR></TABLE>
http://www.intellexual.net/hid.html will help show how the bluer the light, the more glare.
Old Sep 25, 2004 | 01:20 PM
xTurtle714x's Avatar
man 12000k is like having a driving wht black lights..u dont wanna go anthing higher than 6000k
maal15
Dec 13, 2008 11:30 AM
SilverWarrior
Oct 12, 2007 03:03 PM
dohc_profile
Apr 18, 2006 10:42 PM
B2FiNiTY
Oct 2, 2003 10:11 AM
