H22 Swapped into CRX
Old Sep 24, 2004 | 06:47 PM
blackHondaB16Gen1's Avatar
Default H22 Swapped into CRX
I am trying to swap an H22 into my 89 CRX, which currently has a b16 in it. I will probably buy the engine from JDM which si about $2300. Does anyoen knwo how much this swap usually coasts approximately and what all extra work/parts you need. I heard you shoudl replace the axles and suspension when you dot hsi swap due to increased weight.
Old Sep 24, 2004 | 06:49 PM
Jurassic Four's Avatar
From: Where you cant steal it, Maryland, United States
Default Re: H22 Swapped into CRX (blackHondaB16Gen1)
Try seaching at the top right of your screen. member 2point2 did the swap. You will find alot of info on his thread... it is alot of pages.
Old Sep 24, 2004 | 06:51 PM
Default Re: H22 Swapped into CRX (Jurassic Four)
Ok cool, tried searching didnt find any posts really but if you have it coudl you send me a link to that page. Thx
Old Sep 24, 2004 | 06:52 PM
search for h22 CRX, the thread is the first one I think... it is 18 pages.
Old Sep 24, 2004 | 06:53 PM
HatchBox's Avatar
Skoobie no more...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackHondaB16Gen1 &raquo;</TD></TR><TR><TD CLASS="quote">I am trying to swap an H22 into my 89 CRX, which currently has a b16 in it. I will probably buy the engine from JDM which si about $2300. Does anyoen knwo how much this swap usually coasts approximately and what all extra work/parts you need. I heard you shoudl replace the axles and suspension when you dot hsi swap due to increased weight.</TD></TR></TABLE>
Been covered, My suggestion is find the guy who is making the B- h series conversion plates. THen you can bolt up your B16 trannny to the H22
And no need to beef the suspension up, h22 is only 60 lbs heavier then bseries
Old Sep 24, 2004 | 06:54 PM
Default Re: H22 Swapped into CRX (HatchBox)
Oh ok, I have a gsr tranny.
Old Sep 24, 2004 | 07:17 PM
Crakadic's Avatar
http://www.collectiveracing.net
Check out the forums under General and you will see a very picture oriented h22 swap done in a CRX.
Old Sep 24, 2004 | 07:29 PM
Maddox's Avatar
B series H series Plate .. The best way to go...
Old Sep 24, 2004 | 08:24 PM
B16 ED9's Avatar
Default Re: (AllMotorCRX161)
SEARCH , a member named 2point2 has this set up, check with him
Modified by B16 EF at 11:34 PM 9/24/2004
RA122324
21
May 7, 2013 06:26 PM
ivan_h22_turboed
Apr 27, 2008 05:04 PM
ekkkk20
34
Mar 26, 2008 10:13 AM
hondastudent1on1
May 29, 2007 06:37 AM
CrxSiR-GNY
32
Nov 28, 2004 04:28 PM
