Is it stupid putting itr sway bar on ??
Old Sep 24, 2004 | 05:58 PM
G-bonic's Avatar
Hijacked
Default Is it stupid putting itr sway bar on ??
Like is said is it stupid or being dumb putting jdm ITR sway bar on LS, GSR, RS, GS... my newbie friend its stupid... hahaha lmao he just hating coz he doesnt have one... i wanna prove him that its not a waist and stupid. (and plus that why theres a word called UPGRADE)
Old Sep 24, 2004 | 06:24 PM
Heylookits shawn's Avatar
Default Re: Is it stupid putting itr sway bar on ?? (Stock_LS)
no getting an itr rear sway isnt a waist. its not a waste either. bad grammer aside its one of the best bang for the buck suspension mods you can do.
Old Sep 24, 2004 | 06:28 PM
dFreezy's Avatar
Default Re: Is it stupid putting itr sway bar on ?? (Heylookits shawn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Heylookits shawn &raquo;</TD></TR><TR><TD CLASS="quote">bad grammer aside.</TD></TR></TABLE>
bad spelling aside too
he's correct though, its one of the most cost effective mods you can do for an integra. anyone that has done it will probably agree. i got all the parts including the bsq kit for $121
mstyper's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Heylookits shawn &raquo;</TD></TR><TR><TD CLASS="quote">no getting an itr rear sway isnt a waist. its not a waste either. bad grammer aside its one of the best bang for the buck suspension mods you can do.</TD></TR></TABLE>
Old Sep 24, 2004 | 06:30 PM
ponytd's Avatar
no it is a good upgrade. there really isn't much sense in getting the jdm over the us, unless you really want that 1mm extra or to say that you have a jdm. get it and put it on. although your car will handle different, so be warned.
Old Sep 24, 2004 | 10:57 PM
fenix77's Avatar
I got one installed on my GSR last year....it does make a difference, but reading through a few ITR swaybar posts on HT will make you think that you arent even going to recognize your car after the install....bottom line is its better, but not night and day like some say.
Old Sep 24, 2004 | 11:18 PM
aeon's Avatar
i can't see why this upgrade would be a waste.. unless you're all for show then i guess you shouldn't get it.
Old Sep 25, 2004 | 12:01 AM
Curtisbeef's Avatar
Heh i just put mine in the other day...
Its awsome
Its taking me sometime to get used to going around turns because the *** end loves to come out now... i allmost did a 360 the otherday with my friend in the car...
ill give you 1 peice of advice... dont break while turning or the *** instantly comes out...
Old Sep 25, 2004 | 06:29 AM
Outkasted24's Avatar
Default Re: Is it stupid putting itr sway bar on ?? (ponytd)
My buddy has the USDM ITR Sway (22mm) on his '00 Ls and I have the JDM ITR sway (23mm) on my '99 Ls.
We both have the same exact suspension set ups but each car acts differently in high speed turns due to that 1 extra mm thickness.
An ITR Sway bar upgrade is by far the best bang for your buck suspension mod.
Do It, You won't regret it
Old Sep 25, 2004 | 07:18 AM
batmang yO!
Guest
Posts: n/a
Just remember whether its a JDM, USDM, or some aftermaket brand, a sway bar is just a solid piece of metal or at the very least a very rigid group of metal conected to make a bar! geesh! how complicated can a "bar" get? comeone its basicly a fooking broom stick!! (although I wouldn't advise using a broom stick!! LoL )
Old Sep 25, 2004 | 06:50 PM
aeon's Avatar
Default Re: Is it stupid putting itr sway bar on ?? (Beavis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Beavis &raquo;</TD></TR><TR><TD CLASS="quote">Just remember whether its a JDM, USDM, or some aftermaket brand, a sway bar is just a solid piece of metal or at the very least a very rigid group of metal conected to make a bar! geesh! how complicated can a "bar" get? comeone its basicly a fooking broom stick!! (although I wouldn't advise using a broom stick!! LoL )</TD></TR></TABLE>
might just be a bar to you, but it's a really good upgrade for the money. so it isn't just any bar you stick onto your car.. it actually helps out with performance/handling.
Old Nov 10, 2004 | 09:45 PM
dt4life's Avatar
Default Re: Is it stupid putting itr sway bar on ?? (aeon)
What would be an advantage of the comptech tie bar/ sway bar combo, compared to the ITR sway bar. Is it true the itr sway bar can tear apart the chassis? I've heard that in the past and never really made sense to me.
I guess if it did, you guy's wouldnt be praising it.
Old Nov 10, 2004 | 09:53 PM
gsr-2nr's Avatar
Default Re: Is it stupid putting itr sway bar on ?? (wannaTypeR)
id rather get the comptech over the itr b/c 1. u get a tie bar also and 2. im not xactly crazy about drilling into my sub frame u mess up u mess your **** up 2
Old Nov 11, 2004 | 04:50 AM
dFreezy's Avatar
Default Re: Is it stupid putting itr sway bar on ?? (gsr-2nr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsr-2nr &raquo;</TD></TR><TR><TD CLASS="quote">id rather get the comptech over the itr b/c 1. u get a tie bar also and 2. im not xactly crazy about drilling into my sub frame u mess up u mess your **** up 2</TD></TR></TABLE>
when you consider that the comptech rear sway/tie combo is almost 3 times the price of what you can pay to get the itr, it doesnt seem worth it to me. you don't necessarily have to drill your subframe either. you need to drill the abs bracketing thats attached to the subframe and knock out a tack weld on the subframe, but thats it. people have been running this setup for years with no problems- even people who use their cars for autocrossing which would put a little more stress on that area than a daily driver.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wannaTypeR &raquo;</TD></TR><TR><TD CLASS="quote">What would be an advantage of the comptech tie bar/ sway bar combo, compared to the ITR sway bar. Is it true the itr sway bar can tear apart the chassis? I've heard that in the past and never really made sense to me.
I guess if it did, you guy's wouldnt be praising it.</TD></TR></TABLE>
the comptech is adjustable, thats the only 'benefit' i could imagine. you can tear out the subframe if you don't use a mounting kit like BSQ or Beak's.
Old Nov 11, 2004 | 09:06 AM
dt4life's Avatar
Default Re: Is it stupid putting itr sway bar on ?? (dFreezy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dFreezy &raquo;</TD></TR><TR><TD CLASS="quote">
the comptech is adjustable, thats the only 'benefit' i could imagine. you can tear out the subframe if you don't use a mounting kit like BSQ or Beak's.</TD></TR></TABLE>
Thanks dude, you seem to answer all my questions. I appreciate it alot.
In the civic forum, people just start bashing you. Plus if you ask a question everyone just say SEARCH, even after hours of searching.
Old Nov 11, 2004 | 10:15 AM
dFreezy's Avatar
most of the h-t forums are like that unfortunately. most fools will just tell you to search without providing any actual assistance at all. the general consensus is to assume that the person hasn't search there will always be questions that are repeated that could be searched, always people asking seemingly silly questions, and always be noobs so it doesnt bother me. we all started somewhere
Old Nov 11, 2004 | 10:19 AM
dt4life's Avatar
Very true. When I get my stuff, I'll let you know how it went.
threatcon13's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dFreezy &raquo;</TD></TR><TR><TD CLASS="quote">most of the h-t forums are like that unfortunately. most fools will just tell you to search without providing any actual assistance at all. the general consensus is to assume that the person hasn't search there will always be questions that are repeated that could be searched, always people asking seemingly silly questions, and always be noobs so it doesnt bother me. we all started somewhere </TD></TR></TABLE> amen. Glad to see that there are other people who think that search ***** are getting out of hand. I believe the comptech tie/swaybar combo to be the best there is, but bang for buck, the ITR rear sway w/ BSQ Mounting kit. The reason I think the comptech is the best is because the tie bar basically has no pivot points and is a straight through design, and also gives excellent mounting points for the swaybar.
Old Nov 11, 2004 | 11:09 AM
2005 TSX's Avatar
To answer, as a few already have done...no, it's not stupid to put a ITR rear sway bar on.
This modification/upgrade <U>IS</U> one of the best bangs for the buck!
- Doesn't take a long time to install.
- Done properly, it will not tear out your subframe. Make sure to use the mentioned Beak's or BSQ kit. (Note: IF DONE IMPROPERLY...it can very well damage your subframe.)
- Make sure to use some type of lube for the rubber mounts that actually touch the bar. I think a year or so ago, someone mentioned using a Lithium grease. I need to do this since my bar squeaks and moans against the rubber in turns and on cold mornings.
- I am not sure you would notice a giant difference between a US ITR (22mm) and JDM ITR (23mm) sway bar...but then again...I have only used the US sway bar. Someone on here once had a mathematical formula for finding the tension or torsional strength for different size sway bars. I'll try to find it.
My experiance:
I bought a 2001 GS-R, 2 door. Took a really tight turn a little to fast (around 30mph), lost control of the back end, overcompensated, and slid off into the dirt.
Learned how to drive a front wheel drive car.
Purchased a ITR rear sway bar and miscellaneous parts for around $110 about 2 years ago.
Installed the parts using the BSQ mounting kit.
The car now handles a lot better...very predictable...can take turns much faster, safer, and with more confidence now.
The only problem that I am curently having is that the bar makes squeaking noises when it is cold...that's it.
Then I got the following for my suspension:
Upper Front Type-R Strut Bar...$65 off of eBay.
Upper Rear Honda Access Type-R Strut Bar...$180 off of IPSracing.com
And I am in the process of doing research for the rest of my suspension.
See my website in my signature for some pictures.
Any more questions...just ask...I am more than willing to help out.
Old Nov 12, 2004 | 07:30 AM
acuratuner00's Avatar
i got the front and rear sway bars.....
they kick ***......
Old Nov 12, 2004 | 01:26 PM
EminemGSR's Avatar
tell him to sit in the car with you after the install when you're whipping around turns at 60+ mph
Old Nov 12, 2004 | 10:37 PM
yee SERIOUS's Avatar
so everyone is using their stock front sway? wouldn't it be better to get both the front and the rear sways?
from reading all of this, i'm guessing that there is more oversteer with just a rear sway upgrade?
Old Nov 13, 2004 | 10:26 AM
SMZ GSR's Avatar
Default Re: (LiTtOGPiMp)
If I remember correctly, GSR has same front sway as ITR.
Old Nov 13, 2004 | 10:47 AM
deejaycherub's Avatar
tell them if he thinks it's stupid, honda is stupid for wasting a lot of money making a thicker, better functional one for ITRs that are known for great handling... what a dope your friend is...
Old Nov 13, 2004 | 10:49 AM
G-bonic's Avatar
Hijacked
Default Re: (SMZ GSR)
i believe the stock front sway for dc's are thick enough already at least 20 something mm. correct me if im wrong... but the rears are really thin at least 16mm. except the usdm itr is 22mm. while the jdm one is 23mm..
