Rear window
Old Sep 24, 2004 | 03:49 PM
lswift's Avatar
Default Rear window
ok mods if this isnt tech enuff just move it plz... can yall tell me how the F@ck you clean your rear windows in coupes? i swear to god my ****** arm gets ready to fall off and whatever i use just isnt good enough. ive been using this foaming glass cleaner to windex they all suck and are streaky. also what would u reccomend for Si rims? best cleaner. thanx H-T!
Old Sep 24, 2004 | 04:51 PM
Stoich EG2's Avatar
Default Re: Rear window (lswift)
SIMPLE GREEN!!@O*&!^*(@! I just cleaned my rims, washed my car, washed my engine bay, mowed the lawn, washed some dishes, did some laundry, and cleaned my interior with SIMPLE GREEN! Simple Green is used for HELLLA STUFF. just dilute it with water.
NOTE: did not use it to mow my lawn
Old Sep 24, 2004 | 04:58 PM
SOHC4life 96's Avatar
Default Re: Rear window (Advan06)
Well if you have tinted windows Simple Green might be a bit harsh even if its deluted. I just use a paper towel with soapy water and work quickly. Works great on my tint. I do get streaks if I dont move fast enough but nothing is perfect. As for the SI rims I would also like to know. I have some water spots that I cant seem to get rid of.
Old Sep 24, 2004 | 06:38 PM
lswift's Avatar
Default Re: Rear window (DOHC4life)
cool, bump for da rims they are polished aluminum im pretty sure. ill try some simple green on them if nothing else.
Old Sep 24, 2004 | 06:40 PM
Kyles ej1's Avatar
what do u use to wipe it with. if u use newspaper it works the best even if u use windex
Old Sep 24, 2004 | 06:46 PM
lswift's Avatar
Default Re: Rear window (egcoupe)
hmmm been using paper towels, newspaper does work better seen my moms used to do it on the house windows.
i found a bottle of this in my house http://www.autozone.com/servle...true safe for SI rims?
Old Sep 24, 2004 | 06:48 PM
PRcivicHB's Avatar
On a car TV show I saw a while back they were showing viewers how to clean a car... For the windows they used a mixture of vinegar(sp), alcohol, and water in a small spray bottle... Ever since then I use that same mixture, it works pretty well... I also use newspaper to clean it, im not sure what they used....
Old Sep 24, 2004 | 06:49 PM
Default Re: Rear window (PRcivicHB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PRcivicHB &raquo;</TD></TR><TR><TD CLASS="quote">On a car TV show I saw a while back they were showing viewers how to clean a car... For the windows they used a mixture of vinegar(sp), alcohol, and water in a small spray bottle... Ever since then I use that same mixture, it works pretty well... I also use newspaper to clean it, im not sure what they used....</TD></TR></TABLE>
Do you know the mixture ratio for that? And its just regular rubbing alcohol right?
Old Sep 24, 2004 | 08:29 PM
crzyfool24's Avatar
- If you have tinted windows,
Get a damp washcloth to whip the windows down
Then I would get a DRY cloth to whipe the streaks away.
By using something dry after cleaning the windows is the trick. It gets rid of all the streaks.
- No tinted windows I would reccomand using 20/20 (WORKS GREAT) or even Armorall Streak free. They both works great. Sometimes you dont even have to worry about streaks with those cleaners.
About the rims -
I use simple green. **** works great on rims and tires. I spray the hell out of my rims and tires and let it sit for a couple min. I scrub the tires down a lil just to get the buildup off then rinse. Comes out lookin like new.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Advan06 &raquo;</TD></TR><TR><TD CLASS="quote">SIMPLE GREEN!!@O*&!^*(@! I just cleaned my rims, washed my car, washed my engine bay, mowed the lawn, washed some dishes, did some laundry, and cleaned my interior with SIMPLE GREEN! Simple Green is used for HELLLA STUFF. just dilute it with water.
NOTE: did not use it to mow my lawn</TD></TR></TABLE>
Nice haha
Kyle700
15
Oct 10, 2014 07:02 PM
kharned08
Mar 2, 2008 04:32 AM
fongyz22
Honda Civic (2001 - 2005)
Dec 24, 2007 02:18 PM
Ronin Integra8
Dec 17, 2002 10:49 AM
PnX-R
Feb 9, 2002 09:16 AM
