Problem with 1990 civic DX
Hi guys, well i have a problem not too sure what it is.... when i take my foot off the clutch the car lurches alot as if something is rubbing in the wheel well or the ebrake is stuck on, but the wells arent rubbing and my brake is off, i checked the cable its all fine. now i know if u let the clutch out improperly it does lurch but this is rubbing and makes an odd humming noise at first.... any ideas?
Jack the wheels off the ground and make sure they spin freely.
Try to figure out where that noise is coming from.
Did this just all-of-a-sudden start happening???
Hey, a local.
Ok, I'm a little confused. Is this the rear or the front doing this? If it's the front, it could be a sticky brake caliper. Shouldn't cost more than a few dollars to get some re-mans from Lordco or Canadian Tire. If it's the rear, check the star adjuster on the drum. If it's too far out, the shoes could be rubbing against the drum.
lol local where you from? and hmm not sure thats also another good point, my friend says he thinks its the gear slipping but he doesnt know all that much, imma try to get a video with sound of what it does for a better diagnosis unless i cna check for what u said easily?
PS its the front
PS its the front
ddougss_honda
Mar 28, 2009 07:25 AM
Luserkid
14
Nov 5, 2003 01:56 PM
Homer_Simpson
Mar 21, 2002 12:35 PM
