Type-S 5 lug swap?
Old Sep 24, 2004 | 10:32 AM
Mr.TecH7's Avatar
Default Type-S 5 lug swap?
Have any of guys done the 5 lug swap on your EP3's? if so any problems or was it
just straight forward... K-series.com gives a how to but i want to know from others
that have done the swap.
Old Sep 24, 2004 | 10:36 AM
djvtoner's Avatar
Default Re: Type-S 5 lug swap? (Mr.TecH7)
bump....i'd like a little more insight too
Old Sep 24, 2004 | 06:42 PM
SuperRacerTypeR's Avatar
Default Re: Type-S 5 lug swap? (djvtoner)
i did it on my si, yes i ran to a bunch of problems, the rear is pretty straight forward and the front, i have problems w/ the front knuckles and axles. alignment is another problems since i brought the parts from a totaled rsx. so make sure u buy those parts from a striaght and clean rsx. seriously i don't think the rsx-s 5lug conversion is worth it. the only thing is good about it is better braking, and look cool w/ the 5 lug conversion.
parts u will need is..
Hubs
axles(type-s)
type-s sensors
knuckles
brake rotors
type-s brake lines
calipars
new brake pads
Old Sep 24, 2004 | 10:37 PM
97 TYPE-R 312's Avatar
Default Re: Type-S 5 lug swap? (SuperRacerTypeR)
The axles and the ball joint on the front was a bitch! I wanted better braking and the use of 5 lug so I can interchange wheels with my DC2R. With stock RSX-S brake pads, braking was improved. Made it even better with AZENIS and Cobalt GT's all around. I recommend it.
-Victor
Old Sep 26, 2004 | 06:57 AM
g0df8the12's Avatar
trade your in for the 04's or 05's....j/p
Old Sep 26, 2004 | 10:34 AM
SiFuSpEc's Avatar
Default Re: Type-S 5 lug swap? (g0df8the12)
it's nice to do a swap like that, too bad they dont come with 5 lug already..
Old Sep 26, 2004 | 10:35 AM
George Knighton's Avatar
H-T Order of Merit
I have to admit it'd be nice to be able to trade wheels between the EP and the ITR.
It's not a high priority, but I'll probably do the swap one of these days.
Old Sep 27, 2004 | 08:28 AM
Mr.TecH7's Avatar
Thanks for info. I have all the parts, but i didn't think about the senors.
About alignment, i'm already dealing with alignment issues on my 03 Civ.
I picked up all new dealer parts, so maybe those issues should be corrected.
5 lug, bigger brakes, more wheel selection... i think its worth it
Old Sep 30, 2004 | 03:16 PM
safraz's Avatar
go to my web page http://www.safrazonline.com i did it
Old Oct 1, 2004 | 04:08 AM
Mr.TecH7's Avatar
Default Re: Type-S 5 lug swap? (safraz)
i see you also changed the tails to the 04 style... i personaly like the all red type
02-03.... it also looks like u used the 04 Civic 5 lug not the Type-S.... nice mod
though.
Old Oct 1, 2004 | 04:45 AM
djvtoner's Avatar
How much was it for the parts and what exactly did you get from the dealer?
I saw on K-series.com that you didn't need the calipers right away you could use the stock Si caliper... Is this true?
Trying to get ready to do a switcheroo too
Modified by djvtoner at 5:00 PM 10/1/2004
Old Oct 1, 2004 | 10:20 AM
Mr.TecH7's Avatar
RSX non type-s has the same calipers as the Civic Si (front and rear)...
RSX-S has a larger front caliper than that of the Civic front.... but if u went to
K-Series.com u would know that.
"How much was it for the parts and what exactly did you get from the dealer?"
a little under $600 for rear parts...... front parts about a $1000 (could be less, i got
some used parts too)
... not mention rims that those new 5 lugs will hold
i'm sure u could find for less.... Good Luck
FWI... if u want to save $$$ go with 04 Civic 5 lugs.
Old Oct 1, 2004 | 11:04 AM
djvtoner's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.TecH7 &raquo;</TD></TR><TR><TD CLASS="quote">RSX-S has a larger front caliper than that of the Civic front.... but if u went to K-Series.com u would know that.</TD></TR></TABLE>
I did go to K-series.com....
Now for the front. The Base RSX uses the same front brakes as the Si except for the 5 lug pattern. But you can't separate the hub from the knuckle without a press, so you have to install the knuckle and brake assembly. May as well install the Type S front brakes then, <U>unless</U> you just want the 5 lug pattern and will reuse your original calipers. The RSX ball joint fits in the control arm, but make very sure that rubber boot is good and the threads are not damaged - the nut should screw on and off easily. If the nut sticks you won't be able to tighten the ball joint. Here's the parts required for the front, the brake/knuckle assembly and brake line. These are from the Type S.
...straight from the site... i just want the 5 lug pattern for now
That's why i was was asking if it was true...
... Don't give me a hard time for asking a question...
The reason i'm asking is because I'm in the middle of rebuilding my motor with forged pistons, Stage 2 clutch, Flywheel plus some other stuff.... so i really don't have the money to be throwing around for new calipers when i don't need them....
Old Oct 1, 2004 | 02:30 PM
Mr.TecH7's Avatar
Did i make u nervous?... it seemed like u studdered
But really, is that all necessary? It really is not that serious!!!
...............Good Luck on your build up and "switcheroo"(as u put it)!
Old Oct 1, 2004 | 08:56 PM
K20 EM2's Avatar
the 04 do come w 5 lug
Old Oct 2, 2004 | 03:47 AM
safraz's Avatar
ok that is a 04 5 lug. y spent time install a type s that will not work, if you want a type s you need to get the civic type r 5lug. what i did on my car, the hold back is a 04 and the front is not, i only change the knuckles, Pads, Rotor dust covers, Rotor, bearing and Hubs.
Old Oct 3, 2004 | 06:14 PM
mrDFWmechanic's Avatar
i'm thinkin about doin the rsx 5 lug for my 7thgen civ
TommyEp3
Sep 19, 2013 02:42 PM
strtracedrmr
Honda Civic (2001 - 2005)
Apr 4, 2007 07:05 AM
whiteknightef
Dec 11, 2005 03:51 PM
thundergrey94ls
Nov 11, 2005 10:36 PM
