Hf crx.... change to si knuckles?
OK the hf knuckle/hub assembly has to be changed out. You gotta take the whole upper and lower ball joints off and remove the castle nuts. Be carfeul not to bend any thing. Take all that stuff and throw the Si on the Hf in reverse order. Shouldn't take you more then 2 hours.
I picked up both sides of the SI knuckle/hub assembly for under 300$. It's awesome the Integ axels fit perfectly. Go down to a dealer and just order the Spindle nut(32mm) it's cheaper then most Stores at the dealership. Trust me i didn't beleive it either. Just make sure your rims can accomodate the huge rotor/brake upgrade.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JohnnieChimpo »</TD></TR><TR><TD CLASS="quote">You must change the outer CV joints to DX/Si or change the whole axle to the Si/DX.
I know for sure because I've done it</TD></TR></TABLE>
Yep thats is 100% correct. Also if you want a set of complet Si/DX knuckles I got a set for sale $50+shipping.
DsMWookie
36
Aug 31, 2005 10:07 AM
mobrep
May 25, 2002 02:51 AM
