Can't find source of oil leak.....
Old Sep 24, 2004 | 04:15 AM
immalooser's Avatar
Default Can't find source of oil leak.....
Hey guys i'm having a terrible oil leak on my 96 Accord w/ a F22b1.
From what i can tell the leak is coming from the passenger side of the motor. I can follow the leak it goes from the distributor flows down past the starter to the bottom of the transmissision mount and finally ends up at the bottom of the transmission.
Now I changed out the distributor O-ring, number 6 in the the diagram below:
The O-ring didn't do a thing, it still leaks. Are there anything else that could be the problem?
Old Sep 24, 2004 | 05:42 AM
Mike813's Avatar
Default Re: Can't find source of oil leak..... (immalooser)
try cleaning the surrounding area, then take a look again,,, have you checked the valve cover? for me it was the #6 o ring when mine leaked.
Old Sep 24, 2004 | 05:54 AM
immalooser's Avatar
Default Re: Can't find source of oil leak..... (Mike813)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mike813 &raquo;</TD></TR><TR><TD CLASS="quote">try cleaning the surrounding area, then take a look again,,, have you checked the valve cover? for me it was the #6 o ring when mine leaked.</TD></TR></TABLE>
It is leaking b/c the oil drips onto my garage floor. I'm kinda thinking that i didn't install the O-Ring right b/c before it would leak but not as bad as now. I also feel that the honda dealership gave me the wrong part number.
I'm pretty sure it's not the valve cover gasket but i think i'll go ahead and change it anyways.
Any other ideas?
Old Sep 24, 2004 | 07:03 AM
Turbowa's Avatar
Remember when replacing the valve cover gasket to put some Hondabond on the corners and the cam rolls on both sides to prevent it from leaking.
Old Sep 24, 2004 | 09:16 PM
ac9cor6d's Avatar
Ya i have a 96 accord too and i have had to change the valve cover gasket cuz i had a oil leak too that is probably where the problem is but to be on the save side change the oil pan gasket too just to be sure
02ram4by4
Mar 29, 2007 02:17 PM
Fat Chick Magnet
Nov 25, 2006 03:08 PM
johnca
Oct 25, 2006 05:59 PM
jam36a
Aug 19, 2006 09:56 AM
Ghostyman
Nov 1, 2005 12:31 PM
