Project Turbo GS-R!! ** (56k Warning) **
Old Sep 23, 2004 | 09:07 PM
B00ST2nR's Avatar
Default Project Turbo GS-R!! ** (56k Warning) **
Ok, so I was a hardcore All-Motor guy a couple months ago. I got to drive a Turbo Integra during that time, and it really blew my All-Motor pride out the door. The turbo teg was so much faster and much more fun to drive. So... the bug bit me and I decided to goto the Dark Side...
I first planned to go with a simple GReddy Bolt-On Turbo Kit. Was planning to spend $3000.00 total. Well, after doing alot of research, I decided to go with a Custom turbo kit and get quality products. I've learned that doing it RIGHT from the beginning will save me alot of $$ and headaches later on. So I said **** it, and decided to go all out. Besides, ya know the saying "You get what you pay for."
Well, here we go. I'm getting REALLY close to completing my Custom Turbo kit finally after spending a SHIETLOAD of $$$$. I just need a couple more things, like a Fluidyne Half-Core Raidator, Slim size fan, oil catch can, intercooler, charge pipe, and dump tube. After that, I should be ready to install everything and Dyno Tune it.
A little background info:
I have a 2000 Integra GS-R, with about 13,000 miles currently. Only driven on weekends. Garaged on the weekdays. Never seen rain, and kept in immaculate condition. (Thank God for my commute car).
<U>My previous All-Motor setup:</U>
- Skunk2 Stage 1 Cams
- Skunk2 Cam Gears
- Skunk2 Intake Manifold
- Header-Tech Custom Race Header
- ITR AEM CAI
- Tanabe Super Hyper Medallion Exhaust
- Chipped p28 ECU
- Apex'i V-AFC
- AEM Fuel Rail
- B&M FPR w/ Gauge
- 15" Rota Slipstreams
- Bridgestone Potenza Tires
- H&R Sports Springs
- Benen 3 point Strut Bar
It was pretty quick. Fun to drive, and I loved how the motor sounded.
<U>Here's my Turbo setup:</U>
- Benson Sleeved Block
- CP 9:1 Forged Pistons
- CP Forged Piston Rings
- Eagle H-Beam Rods
- ARP Head Studs
- BLOX Turbo Camshafts
- Buddy Club Raciing Titanium Cam Gears
- Supertech Valve Springs
- Supertech Titanium Retainers
- Precision SC61 Turbo
- OneFab "Equal Length" Turbo Manifold
- OneFab 3" inch Downpipe
- Spoolin Performance Dump Tube
- Spoolin Performance Charge Pipe
- Front Mount Intercooler w/ Piping
- Tial 38mm Wastegate
- Tial Blow Off Valve
- SS Braided/AN Fitting Return Line
- GReddy Turbo Timer
- GReddy Profec B Spec II Boost Controller
- GReddy Boost/EGT/Oil Pressure Guages
- Autometer Full A-Pillar Tripple Pod
- GReddy Oil Catch Can
- GM 3 Bar Map Sensor w/ Pigtail Harness
- Custom Fabricated Half-Core Radiator
- Slim Size Radiator Fan
- Hondata S200B
- OBD1 P28 ECU
- Skunk2 OBD2-OBD1 Harness
- Walbro 255 LPH Fuel Pump
- RC 750cc Injectors
- AEM Hi-Volume Fuel Rail
- B&M Fuel Pressure Regulator w/ Gauge
- Thermal 3" Inch Turbo Exhaust
- Carsound 3" Inch Catalytic Converter
- ACT XTSS
- ACT Streetlight Flywheel
- Benen 3 Point Strut Bar
- Rear Strut Bar
- 16" Royal Bronze w/ Polished Lip Rota Grids
- 215/40/16 Falken Ziex Tires
- Type-R Seats
- Type-R Center Console
- Type-R Side Door Panels
- Razo Shift ****/Pedals
- OEM Kit
- JDM Valve Cover
- Invidia Carbon Fiber Spark Plug Wire Cover
Here are pictures of some Turbo parts I have. It hurts me to see these laying in the corner of my room and not in the car already! -
One Fab "Equal Length" Turbo Manifold
One Fab 3" Inch Down Pipe
Thermal Full Stainless Steel 3" Inch Turbo Exhaust
TIAL 38mm WG
TIAL Blow Off Valve
Eagle H-Beam Rods
Buddy Club Racing Titanium Cam Gears
Supertech Valve Springs and Retainers
ARP Head Studs
RC 750cc Injectors
Walbro 255lph High Pressure Fuel Pump
ACT XTSS Clutch and ACT Streetlight Flywheel
Autometer A-Pillar Tripple Gauge Pod
GReddy EGT/Boost/Oil Pressure Gauges
GReddy Profec B Spec II Boost Controller / GReddy Turbo Timer
Hondata S200 Boost w/ P28 ECU
And since Cali cops suck, here are some GReddy CARB Stickers I will be putting on once I get everything in there. Just in case I get pulled over and they say ****. I can just point to the stickers and tell them it's a legal kit.
Hopefully, it'll be all done and up and running by the end of the year. My goal is to make around 350-400wHP.
If you guys have any advice, comments or questions, you're more than welcome to ask.
I've been around Honda-Tech for awhile, so I just wanted to keep the Integra family updated on my lil project.
Modified by B00ST2nR at 11:04 PM 10/28/2004
Old Sep 23, 2004 | 09:11 PM
.water's Avatar
Default Re: Project Turbo GS-R!! ** (56k Warning) ** (B00ST2nR)
Old Sep 23, 2004 | 09:14 PM
Ti3d in's Avatar
Default Re: Project Turbo GS-R!! ** (Milano-Red GSR)
Damn talk about money. And 13K on a 2000 GSR. My 2000 has 103K hahah. Good luck with everything.
Old Sep 23, 2004 | 09:15 PM
RidinStock's Avatar
Holy ****... you weren't lying when you said you were going all out. You said you planned on spending around $3000 but my guess is you spent way more than that for all that work... to your setup though, looks good!
It's nice to see someone do it all right from the start. I would like to do the same (starting w/ a swap for lower mileage) but my pockets aren't that deep. Keep us updated!
Old Sep 23, 2004 | 09:16 PM
W.O.P.'s Avatar
ummm....... WOW. i cant wait to see this fall through for you!!! keep us posted, which im sure you will! im jealous
Old Sep 23, 2004 | 09:18 PM
user 996328629's Avatar
Nice as hell!
I wish i would have taken pics of all my **** layin around before i installed it..
LET ME KNOW HOW THAT CLUTCH is!
Ill be needing a new one after this winter
What about a LSD?
Old Sep 23, 2004 | 09:20 PM
B00ST2nR's Avatar
Default Re: Project Turbo GS-R!! ** (Swags04)
Thanks for the kind words everyone.
LSD
Traction Bars
Tein Suspension
Brake Upgrade
are the 4 things I'm getting after my car is Turbo'd. But for now, I gotta lay off my wallet.
Old Sep 23, 2004 | 09:21 PM
J-Brooks's Avatar
Default Re: Project Turbo GS-R!! ** (1quickLS)
Nice setup... you did alot of the same stuff I did! Good luck!
Old Sep 23, 2004 | 09:24 PM
viet's Avatar
Default Re: Project Turbo GS-R!! ** (J-Brooks)
money well spent.
Old Sep 23, 2004 | 09:41 PM
Vtecfool's Avatar
Default Re: Project Turbo GS-R!! ** (viet)
BALLER! Looks like a great setup, keep us posted of the updates
Old Sep 23, 2004 | 09:45 PM
MugenGSRb18's Avatar
thats a lot of dough for all that stuff, but it looks good....especially your turbo manifold.
Old Sep 23, 2004 | 09:46 PM
racingfan's Avatar
damn...whats the grand total of all the stuffs?
Old Sep 23, 2004 | 09:47 PM
Xymox007's Avatar
Default Re: (APEX'i Baby N1)
so where is the pict of the final bill?
Old Sep 23, 2004 | 09:50 PM
Gerbilo's Avatar
Default Re: Project Turbo GS-R!! ** (MugenGSRb18)
Wow, *envy*
Atleast you are doing it right. That is the way that I would like to go about it, best quality everything and get it all done right... unfortunately for myself it'll be a few years in the futre.. but good luck anyway! have fun
Old Sep 23, 2004 | 09:51 PM
B00ST2nR's Avatar
Default Re: (Xymox007)
Oh boy... I spent over $6,000.00 so far and I still have $3k-$4k more to go. The Grand Total will probably be around $10,000.00
Old Sep 23, 2004 | 09:56 PM
Ti3d in's Avatar
Default Re: (B00ST2nR)
Don't forget the cost to maintain it, and to drive it.
Old Sep 23, 2004 | 10:36 PM
95 integra's Avatar
Default Re: (Ti3d in)
looking good to me.
Old Sep 23, 2004 | 10:41 PM
MaskedAP1's Avatar
Default Re: Project Turbo GS-R!! ** (Gerbilo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gerbilo &raquo;</TD></TR><TR><TD CLASS="quote">Wow, *envy*
Old Sep 23, 2004 | 10:50 PM
vain's Avatar
SICK.
Old Sep 23, 2004 | 10:59 PM
xprohx's Avatar
I think too much
Default Re: (vain)
Damn, that's a lot of money to invest in a car. But it looks like your getting what you paid for. Keep us updated on the install.
Old Sep 23, 2004 | 11:38 PM
Undercover_Skank's Avatar
Default Re: (xprohx)
wow...that is alot of money you are spending and its worth it...and yes, do keep us updated!!!
Old Sep 23, 2004 | 11:57 PM
jDMJeRk's Avatar
skunk2nR....
ive alway loved your car; i remember the for sale post to turn to the dark side... i guess its just been a matter of time. i can see you did your home work too... race eng makes probably if the best, one of them, block guards.
one word as advice. ive spent over 5k in just my motor/work done it (machine shop) youll regret not getting it sleeved unless your like me and think you can pull it off.... (my car isnt done yet so i havent got to prove ****, but i do wish i got sleeves; **** why not i got rest of all the stuff)
any how, looks good as usual, GL HF and drive safe
EDIT: i re-read everything and our setsup are EXACTLY the same(well close i bought a b16, and misc different parts), man id sleeve it before its too late. maybe your only going to make little power, but from your statement above (your addicted too boost)youve tasted it once and your going to want more
(note: wish i wasnt hurt; (car accident; i was passenger; elbo broke in 5pcs; ive got months ahead of me for minimal recovery; my motor just sits waiting me unpatiently)
b16
polish/balanced crank
0.5 over bore, re-honed,(misc machine work head+block)
civic type r crank pulley (No PS+AC)
acl bearnings
eagle rods w/arp fasteners
cp 9:1 81.5mm pistons
itr water pump
ls/gsr/itr oil pump
Race Eng. Block Guard
AEBS Head Studs
port polish head
supertech valves (dished top, black nitrate coding)
supertech retainers
supertech springs
gsr cams (temp; good for turbo )
skunk2 cam gears
obd0-obd1 conversion harness
p28 ecu
uBerdata
Bored/Rebuilt TB 62mm-68mm (thx spaceballs)
RevHard Intake manifold
D1 fuel rail (yes the fuel rail you bought that was crap; havevnt tried mine yet)
Whole motor gasket set (oem; stone)
Full Race Traction bar
Prothane motor mount inserts
Autozone Dual Core 94-97 Del Sol Radiator
ive gotten OF big time hope i dont thread jack ya....
AGAIN NICE JOB SKUNK....ID THINK OF SLEVVES... MEMBER YOU SAID YOU WERE DOING IT RIGHT THE FIRST TIME.
::shuts up now::
Modified by jdmjerk at 1:12 AM 9/24/2004
Old Sep 24, 2004 | 12:00 AM
TegRyder33's Avatar
Damn that is a great setup you got goin there man, the list just went on...good luck with it!!
Old Sep 24, 2004 | 12:29 AM
FR-MOB: ThE bEe GuY's Avatar
Dude thats friggin awesome!
BUT, Before you put that stuff in, you NEED to get a **** load of security/anti theft features for your car, it'll be sad to see another "Never thought it would happen to me, car stolen" post here man, SECURITY! Layer n layers of it!!! Especially once you get a FMIC, thieves will be drooling over your car
Old Sep 24, 2004 | 01:01 AM
s2kkid's Avatar
Where can the Race Engineering Hi-Flow Block Guard be found?
I was looking at the golden eagle, which looks like a good piece, but i noticed how this has allot of coolant passages...
I just wonder if all those coolant passages, might possibly weaken the guard?
