Si and DX brake question
Old Sep 23, 2004 | 08:25 PM
spcrxracer's Avatar
Default Si and DX brake question
I was just wondering if crx Si and DX front brake calipers and rotors are the same. I was going to intercahnge the 2 taking the DX front brakes and putting them on the Si
Old Sep 23, 2004 | 08:30 PM
jlicrx's Avatar
Default Re: Si and DX brake question (spcrxracer)
they are the same
Old Sep 23, 2004 | 08:38 PM
EL Vap133's Avatar
Default Re: Si and DX brake question (jlicrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx &raquo;</TD></TR><TR><TD CLASS="quote">they are the same</TD></TR></TABLE>
Old Sep 23, 2004 | 08:41 PM
spcrxracer's Avatar
Default Re: Si and DX brake question (EL Vap133)
ok because looking at the rotors they are the same except the si has crossdrilled. The calipers look like the idiot i bought the car from fucked them up. because the 2 calipers look totaly different. Like he tried some ghetto *** Integra conversion or something.
Old Sep 23, 2004 | 08:44 PM
jlicrx's Avatar
did he put integra knuckles on it? the DX/Si calipers don't fit the integra knuckles
Old Sep 23, 2004 | 08:51 PM
spcrxracer's Avatar
no. its def the si knuckles. i think he just has fucked up calipers
Old Sep 24, 2004 | 07:44 AM
EL Vap133's Avatar
Might as well upgrade to Teg brakes.
Old Sep 24, 2004 | 07:47 AM
crx_88_si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spcrxracer &raquo;</TD></TR><TR><TD CLASS="quote">ok because looking at the rotors they are the same except the si has crossdrilled. The calipers look like the idiot i bought the car from fucked them up. because the 2 calipers look totaly different. Like he tried some ghetto *** Integra conversion or something.</TD></TR></TABLE>
cross-drillled = aftermarket
Old Sep 24, 2004 | 07:53 AM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spcrxracer &raquo;</TD></TR><TR><TD CLASS="quote">I was just wondering if crx Si and DX front brake calipers and rotors are the same. I was going to intercahnge the 2 taking the DX front brakes and putting them on the Si</TD></TR></TABLE>
Rotors are the same.
For calipers, '90-91 CRX Si has different calipers from the '90-91 CRX DX - they take a different pad. They should be interchangheable however.
Old Sep 24, 2004 | 07:54 AM
CRX7's Avatar
NO! 90-91 Si and DX calipers are not the same. I have had both and you have to swap the entire bracket and caliper assembly. The caliper on the Si is larger and the bolts which hold it to the bracket are different. Just make sure you swap the bracket as well.
Old Sep 24, 2004 | 07:56 AM
tilt's Avatar
my 88si and 91dx calipers are not the same.
Old Sep 24, 2004 | 07:59 AM
EL Vap133's Avatar
Default Re: Si and DX brake question (tilt)
Umm, well I used a 90 dx caliper on my 97 dx.
Old Sep 24, 2004 | 11:10 AM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">Umm, well I used a 90 dx caliper on my 97 dx. </TD></TR></TABLE>
That's because they use the same caliper which takes a 273 pad. CRX Si uses a 373 pad.
Old Sep 24, 2004 | 11:32 AM
spcrxracer's Avatar
Default Re: Si and DX brake question (Targa250R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">
That's because they use the same caliper which takes a 273 pad. CRX Si uses a 373 pad.</TD></TR></TABLE>
OK so what i needed to do was change out my 91 si passenger side suspension (everything) with my 91 dx pass. side suspenion. so will i be able to take off the dx rotor and caliper and use the Si's?
Old Sep 24, 2004 | 11:58 AM
Targa250R's Avatar
be professional
OK so what i needed to do was change out my 91 si passenger side suspension (everything) with my 91 dx pass. side suspenion. so will i be able to take off the dx rotor and caliper and use the Si's?</TD></TR></TABLE>
You don't need to swap rotors unless the current ones have a problem, because they use the same rotor. I personally wouldn't bother with drilled rotors anyway.
As for the calipers, they are different but should be interchangeable (as CRX7 mentioned, swap the entire assembly including the bracket).
I would swap both of them, so you don't have 2 different calipers up front.
Old Oct 7, 2004 | 06:05 PM
spcrxracer's Avatar
I would swap both of them, so you don't have 2 different calipers up front.</TD></TR></TABLE>
So then would it be a problem if i use my 91 crx dx front brakes (everything) on the Si?? the dx calipers wont affect the brake balance on my Si will they?
Old Oct 8, 2004 | 04:03 AM
Targa250R's Avatar
be professional
So then would it be a problem if i use my 91 crx dx front brakes (everything) on the Si?? the dx calipers wont affect the brake balance on my Si will they?</TD></TR></TABLE>
There wouldn't be any problem.
The Civic Si used the same front calipers (273 pad) as the CRX DX, Civic DX, etc.; for some reason, they gave the CRX Si the slightly larger front calipers (373 pad) and factory rear discs, but not the heavier Civic Si.
nexgen91
Jul 10, 2007 01:15 PM
Serdar
Aug 14, 2005 05:35 PM
MAD SCIENTIST
Apr 19, 2004 06:05 PM
RotiEatter
10
Jul 24, 2003 12:52 PM
xhatchracerx
Oct 10, 2002 05:59 PM
