STILL NEED HELP. How to sway the green film from the USDM cluster to JDM cluster
Old Sep 23, 2004 | 08:12 PM
shoei's Avatar
Default STILL NEED HELP. How to swap the green film from the USDM cluster to JDM cluster
I'm really a newbie to this stuff. but i like the yellow needle from the JDM type R. how can i take the green film from the back and install back to the JDM cluster?
another question, if i get a 98-01 type r cluster, will i still need to take out the green film from the back? or it'll be plug and play?
thanks so much guys
Quincy
Old Sep 23, 2004 | 08:35 PM
threatcon13's Avatar
New User
Default Re: STILL NEED HELP. How to swap the green film from the USDM cluster to JDM cluster (shoei)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shoei &raquo;</TD></TR><TR><TD CLASS="quote">I'm really a newbie to this stuff. but i like the yellow needle from the JDM type R. how can i take the green film from the back and install back to the JDM cluster?
thanks so much guys
Quincy</TD></TR></TABLE> take out bulbs in back of cluster, then unscrew all screws, take off green film, put it onto other cluster, screw in all screws, plug in all bulbs. really easy, if you can't figure out this DIY, then you might wanna consider a new hobby.
Old Sep 23, 2004 | 08:55 PM
BigDaddy's Avatar
There's no film in integra gauge clusters
You just look at the back of the cluster and pull out Three bulbs...from your original cluster...they should have a bluish/green "condom" on them
just put them in your new one
http://www.geocities.com/mt3c/DIY_Amber_GC.html
this link should help explain where the bulbs are and what they look like
Old Sep 23, 2004 | 09:05 PM
BigDaddy's Avatar
Default Re: STILL NEED HELP. How to swap the green film from the USDM cluster to JDM cluster (BigDaddy)
OK NEVER MIND WHAT I SAID ABOVE...I didnt read the other thread that you have posted...so many people call different parts different things... so anyways...do this....
FORGET the red circles...but do you see the phillips head screw? There should be three screw per guage..
Those are the ones holding your guages in...take out those screws and remove the individual guages....do the same on your old cluster...and them insert the new ones there...forget about messing with the green film...I wouldnt...I changed plenty of guages...just do it this way...
GuitarSlinger78
Aug 16, 2008 01:38 PM
Weak!EG
May 7, 2007 11:07 PM
CivicHB93JDM
Apr 22, 2005 08:50 AM
lshobo
Sep 26, 2001 08:50 PM
