B16 with nitrous
Old Sep 23, 2004 | 07:55 PM
chattownrexer's Avatar
Default B16 with nitrous
Listen I have searched and searched.... I have a very strong b16 in my crx, and I want to run a 50st... I have i/h/e... all cheap stuff like ebay, apc, and maxi muffler.... stuff like that, anyway how long could I run that shot before i break something? Thanks...
Old Sep 23, 2004 | 08:04 PM
Crakadic's Avatar
You can run a 50 shot all day long direct port and it would be fine. I fyou spray through your intake arm you will end up putting most of the NOS into you 1st and 2nd cyl and therfor weaking the 2
Old Sep 23, 2004 | 10:13 PM
Default Re: (Crakadic)
Well what do you run? Do you have nitrous? What set up are you running? How much do you think a direct port kit would cost? A machine shop could do that couldn't they?
Old Sep 23, 2004 | 11:02 PM
Slopoke's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crakadic &raquo;</TD></TR><TR><TD CLASS="quote">You can run a 50 shot all day long direct port and it would be fine. I fyou spray through your intake arm you will end up putting most of the NOS into you 1st and 2nd cyl and therfor weaking the 2</TD></TR></TABLE>
Sorry, but that is a crock of sh*t.
Why would cyl 1 and 2 be getting more nitrous when they are the farthest away from the nozzle?
I ran a 75 shot on an ls motor and a ITR motor for over 2 years with a simple dry system(injects it into the intake).
No problems whatsoever and all spark plugs had similar readings (if 2 cyls were getting more nitrous, those cylinders would be running lean while the others ran rich).
If you take the necessary precautions, your motor will live a very long, happy life.
-Retard your timing
-always run at least 91 octane
-run colder plugs
-dont use nitrous below 3000rpm
-dont use nitrous longer than 15 seconds at a time
Old Sep 24, 2004 | 06:54 PM
gATOr65's Avatar
Default Re: (Slopoke)
[If you take the necessary precautions, your motor will live a very long, happy life.
-Retard your timing
-run colder plugs
[/QUOTE]
true
Old Sep 24, 2004 | 06:59 PM
mar778c's Avatar
Community Builder
Community Influencer
Preach on brother
Old Sep 24, 2004 | 07:27 PM
Crakadic's Avatar
your first 2 cyl from the dist. Get MORE NOS in them because they are closest to the intake arm. If you dont believe that then you are one dumb sob. I dont care what you do when you run a wet/dry setup through an intake arm your first 2 cyl will get more NOS and it will weaken them faster than the last 2.
Old Sep 24, 2004 | 08:06 PM
riceisnicenv's Avatar
listen to slopoke... he is smart.
Old Sep 24, 2004 | 11:32 PM
Loaded Butane's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crakadic &raquo;</TD></TR><TR><TD CLASS="quote">your first 2 cyl from the dist. Get MORE NOS in them because they are closest to the intake arm. If you dont believe that then you are one dumb sob. I dont care what you do when you run a wet/dry setup through an intake arm your first 2 cyl will get more NOS and it will weaken them faster than the last 2.</TD></TR></TABLE>
So what if I use a Zex kit? Will that cure the problem? I'm just wondering because you keep talking about NOS and not NX or Zex.
Old Sep 25, 2004 | 12:11 AM
hahagasdcrx's Avatar
Default Re: (Loaded Butane)
i ran a 50 shot with stock timing and plugs for over 2 years. No problems at all.
Old Sep 25, 2004 | 12:52 AM
biggdogg's Avatar
Default Re: (hahagasdcrx)
plus look at the guys name (crack addict) no damn wonder ! or is it crack a dick .
Old Sep 25, 2004 | 08:38 AM
Slopoke's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crakadic &raquo;</TD></TR><TR><TD CLASS="quote">If you dont believe that then you are one dumb sob. </TD></TR></TABLE>
Ha!
You are a rookie, plain and simple.
In a dry set-up, your fuel injectors are supplying the extra fuel, so each cyl gets the same amount of fuel, regardless of what the nitrous does. So if cly # 3 & 4 were getting more nitrous they would be running lean and #1 & 2 would be running rich(since 3 & 4 are getting some of the nitrous that 1 & 2 are supposed to get).
If that were the case, the spark plugs would read accordingly.
Distribution is not going to be perfect, but it wont be off enough cause any problems.
I checked my plugs regularly and never once did my plugs read noticably different.
They were always nice and consistant.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crakadic &raquo;</TD></TR><TR><TD CLASS="quote"> first 2 cyl will get more NOS and it will weaken them faster than the last 2.</TD></TR></TABLE>
Since when does nitrous cause a cylinder to get weaker?
My Ls swap that I used nitrous on(about 4 years ago) is still running in a friends car and my old itr swap that I used nitrous on(2 years ago) is still running in my brothers coupe and he is currently running nitrous on it again.
Not to mention I have a friend that runs a 90 shot(through the intake *gasp*) on a sentra with 155,000 miles on the odometer. And he goes to the track almost every weekend!
Like I said, take the necessary precautions, use common sense while shooting, and your motor will last a very long time.
Old Sep 25, 2004 | 01:23 PM
Bserieskllr's Avatar
The motor will last if you use it smart....my friend has 91 crx si with b16a, i/h/e and 60 shot runs 13.20 on slicks....been runnin the 60 shot for over a year still running strong, good luck with it and have fun.
Old Sep 25, 2004 | 01:37 PM
kid-honda's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slopoke &raquo;</TD></TR><TR><TD CLASS="quote">
.</TD></TR></TABLE>
I think honda made the manifolds good enough to distribute air pretty evenly and if they did the job right the nitrous will distibute just as well as the air does.
Old Sep 25, 2004 | 02:36 PM
DocSean's Avatar
Default Re: (kid-honda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kid-honda &raquo;</TD></TR><TR><TD CLASS="quote">
I think honda made the manifolds good enough to distribute air pretty evenly and if they did the job right the nitrous will distibute just as well as the air does.</TD></TR></TABLE>
ABSOLUTELY! well said mang
Old Sep 25, 2004 | 06:49 PM
kid-honda's Avatar
Default Re: (spankjelly)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spankjelly &raquo;</TD></TR><TR><TD CLASS="quote">
ABSOLUTELY! well said mang</TD></TR></TABLE>
Just stating the obvious
Old Sep 25, 2004 | 09:18 PM
Thanks guys...... I appreciate the help.... I'll let ya know how it runs...
hoffmanb16
11
Mar 11, 2009 12:01 PM
bam_89
10
Jul 30, 2008 12:54 AM
mattb145
Mar 1, 2007 12:45 AM
SleepingSmurf
Jun 22, 2004 11:19 AM
nitrouspete
25
Nov 2, 2003 12:27 PM
