Swapping from SOHC non vtec to SOHC vtec
Okay Guys my CRX is a 1989 DX, I did the MPFI swap, to a non vtec SOHC ZC Motor I am presently Useing a 1990 Integra LS ECU. I am about to do another swap to a SOHC vtec. what do I need to add in terms of wireing? and also which ECU should I use? it's a 1992 SOHC Vtec, besdies that ECU is there any other I can use? or can I use the integ LS ECU that I have now and use a VAFC to control vtec.Also can I run the Motor with that ECU, and not hook up the vtec for now?Any help is welcomed.
Will The LS Integra ECU Start and run a SOHC VTEC Motor? (No vtec connected)
Thanks.
Modified by crxxxxxx at 6:38 PM 9/23/2004
Thanks.
btcca4
Aug 12, 2004 12:40 AM
