i think i just f'ed up my new carbon friber hood and a question aboult it
From: Murfreesboro, Tennessee, United States of America
well i just now got my carbon fober hood in the mail and i was putting it on my car and stripped the lower bolt no the driver side! it feels like it gets tight but when i put the hood on the hood prop it pops out
and also how do i chang the gap on the sides this is what it looks like
Not too sure how to adjust your hood/bumper gap...but just guessing, see if you can adjust the hood latch height, or hood latch assembly height.
I had the same alignment problems when I got my CF hood. This is what I did. ajust the part of the latch that bolts too the hood tilll you get the gap in the middle to where you want it. Then drill out two big holes one the sides of the hood at the front where the little rubber rests go (look at your stock hood you can tell what im talking about from there). You can then use thouse to ajust the correct level of gap on either side of the hood. As far as side gap goes, the holes on the hood higes ar ovals not circles so try ajusting it from their. Hope this helps!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Synth124 »</TD></TR><TR><TD CLASS="quote">Not too sure how to adjust your hood/bumper gap...but just guessing, see if you can adjust the hood latch height, or hood latch assembly height.</TD></TR></TABLE>
no its not the hood bumper gap its the hood and fender gap
but i need the most help with the stripped scrow hole
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxzcracer »</TD></TR><TR><TD CLASS="quote">BUMP I NEED TO DRIVE MY CAR NOW</TD></TR></TABLE>
put your regular hood on for the time being then...worry about the new one later...
youll have to retap it. im not sure of the size but get a tap the correct size and thread and that should fix the problem.
it looks like it's on crooked..try to adjust the hinge bolts to the hood..some times they have that little play so mess with that.
and as far as the hood and bumper clearence I just did it the getto way and jump on the support until it line up..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxgator »</TD></TR><TR><TD CLASS="quote">
wow, what a concept
Remove hood,
retape threads
Place hood on car
find bolt
Instert bolt into hood
tighten.
Done!
</TD></TR></TABLE>wow, what a concept
Remove hood,
retape threads
Place hood on car
find bolt
tighten.
Done!
steronz
Feb 18, 2004 12:58 PM
