b20 crx
Old Sep 23, 2004 | 12:28 PM
toaster's Avatar
Default b20 crx
i searched for about 30 minutes... but i couldnt find it
i will be using a obd2 b20b into a 91 crx si.
what wiring harness do i need and what mods will i need to make to the harness.
Old Sep 23, 2004 | 12:30 PM
Jurassic Four's Avatar
From: Where you cant steal it, Maryland, United States
Default Re: b20 crx (toaster)
ODD1 computer... adapting harness. And dizzy plugs.
And you obviously didnt search hard enough... if you are doing this swap... you need to read ALOT more.
Old Sep 23, 2004 | 12:36 PM
speed_racer012's Avatar
Default Re: b20 crx (Jurassic Four)
I think you should just be able to run a Ef si harness with some modifacations.
Old Sep 23, 2004 | 12:52 PM
lsvtecarod's Avatar
yea, u can def use si harness
Old Sep 23, 2004 | 01:30 PM
NCchris's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jurassic Four &raquo;</TD></TR><TR><TD CLASS="quote">ODD1 computer... adapting harness. And dizzy plugs.
And you obviously didnt search hard enough... if you are doing this swap... you need to read ALOT more. </TD></TR></TABLE>
Could prob run it non obd with 90-91 distributor, injectors and PR4 ecu. No harness or plugs required.
chris
Sosa0311
Sep 15, 2012 11:14 AM
bronxbomber0215
Mar 13, 2008 11:36 AM
ikaika3269
10
Feb 26, 2008 06:25 PM
Galaxy Si
Jul 30, 2007 05:28 AM
RuffRhyno
Aug 12, 2002 04:22 PM
