Minimum rotor thickness question
Have a 03 V6 m/t coupe and might need to change rotors soon. What's the min thickness? Has anyone used anything besides OEM and got good results?
Lemme guess...
You think you need new rotors because your brakes either squeek or your steering wheels shimmys under braking.
Well just an FYI the factory uses very soft linings on the brake pads so they won't squeek and provide great breaking performance and typically last about 15K. If you go with an aftermarket say vatozone special the linings are very hard which last for 45-60K and provide for decent braking.
Get your rotors relined and slap some new pads on there. If you're looking for an "upgrade" brembo blanks are a great upgrade along with some better pads. I am personally using axxis pads and brembo blanks and the stopping is a step up from oem
But thats just my guess...why do you think you need new rotors?
.But thats just my guess...why do you think you need new rotors?
hey how many miles does your car have because there is a service bulletin from honda to replace the front brakes and to cut the rotors on some 03 accords mostly all of them.....but the limmit is 21mm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by motormanSR »</TD></TR><TR><TD CLASS="quote">hey VRD...how does do your upgrades last compared to OEM?....just curious</TD></TR></TABLE>
so far so good...smooth, great stopping power and I also added some SS brake lines. I will let ya know
Wrong guess.
Got cryo treated Brembro rotors already with Hawk black front and blue rear. After three open track events the front rotors seems that need to be replaced. Just wanted to know how much more I can get out of them.
Thank you for the advice.
I am getting Axxis ultimate and slotted rotors from Rotora, are they any good?
